94 Transmission Output Shaft Seal
sailorcolin
I have a 94 Plated KDX that has a leaky seal. The seal the behind the front sprocket on the transmission. I can do all the work my self to change the seal but I am a new owner to the bike. This being said, I do not know which seal to buy when searching online. I will upload pictures later today as I am at work now. But if some one could point me in the right direction that would be great. I did some google searches and didnt get very far with them. Thanks!
- 6 Riders
Re: 94 Transmission Output Shaft Seal
I needed water pump seals and decided to buy this kit https://www.thumpertalk.com/shop/Moose- ... 67387.html ...pretty nice stuff
sailorcolin
Does that have the necessary seal for my application? Sorry to sound like a noob!
- 6 Riders
All the seals needed to rebuild the motor and transmission. I still have all but the water pump seals if your interested in them
- KDXohio
The seal youre looking for is 92050-033
Click the link and look for the part labled 92050 in the drawing it'll be on the left crankcase
http://www.middletowncycle.com/fiche_se ... &fveh=8585
- rbates9
Don't bother replacing the seal with out also replacing the collar and the two o rings at the same time. If you just replace the seal it will probably start to leak again in a short time.
- KDXohio
Ive had good luck with flipping the collar around but yeah replacing would be better I agree
sailorcolin
The person i bought the bike from had all the seals in the bike replaced 4 months ago. The reason that seal started leaking was beacuse he sprayed this engine cleaner that ate at the seal when he didnt wash it off directly after washing the bike.
