aftermarket rear fender?
kpla51
the guy i bought it from chopped off the light duck taped it and painted over it. crazy i know but what fender could i use and id perfer one without the light just for the fact that im sure he ripped out all the wiring for it
- rbates9
- diymirage
Re: aftermarket rear fender?
and if the search claims MX is too small do a search for "Maier"
(if you do decide to search for MX rear fender the first picture will be a maier fender)
that said, I doubt someone who is professional enough to duck tape and paint over a section of a fender would bother removing the wiring
I would guess if you pull the seat you will find them right there, tucked into the airfilter
if you would like to reinstall a light though it is a whopping 2 wires, should be easy enough to figure out
-1997 KDX 220 project bike
- Has thanked: 103 times
- Been thanked: 26 times
kpla51
what about the switch for the light or was there ever one? does it just turn on when the bike is on ? ill have to look under the seat for the wires.
- diymirage
there should be a switch that looks just like the kill switch but look behind your number plate for a yellow and a red wire
that's where the switch would have gone but I would imagine they just disconnected it
terminatr
I think the OEM fender cost about the same as the aftermarket ones. Why not do OEM.
2001 KDX220
- KDXohio
I dont have a light switch either somewhere along the years someone just put the two wires behind the number plate together
- kawagumby
- Been thanked: 3 times
I agree. The last UFO fender I bought didn't fit worth diddle - had to redrill holes and trim side panels, and the tailight sits up too high. The maier fenders are overpriced and brittle. Both are junk, IMO, so I will buy OEM next time. I just bought some nice polysport front and rear fenders for my TE310, fit and look like OEM, nice heavy plastic, about $20 each. Why the high price for the crappy maiers ? there are more KDX's still out there than many dirt bikes so there's good demand, I would imagine.terminatr wrote:I think the OEM fender cost about the same as the aftermarket ones. Why not do OEM.
- rbates9
Probably because most KDX owners see the price and say F that so the demand is low. I know I wouldn't spend $60+ for the "MX" rear fender.kawagumby wrote: Why the high price for the crappy maiers ? there are more KDX's still out there than many dirt bikes so there's good demand, I would imagine.
- KDXohio
Its like designer clothes less material higher pricerbates9 wrote:Probably because most KDX owners see the price and say F that so the demand is low. I know I wouldn't spend $60+ for the "MX" rear fender.kawagumby wrote: Why the high price for the crappy maiers ? there are more KDX's still out there than many dirt bikes so there's good demand, I would imagine.
