Chain question
meccanj98
- KDXohio
Re: Chain question
measure the gap and measure a link and divide the two then add that number to the number of links you have now and that will give you the new length
meccanj98
- rbates9
Chain question
Try your stock chain and see how close it is. You might be fine. I have a 12 and a 48 and stock chain length with the adjusters about half way out.
- KDXohio
Re: Chain question
Sorry the gap between the ends of the chain you have now with it on the sprockets and the adjuster set forward
- diymirage
Re: Chain question
cant go wrong with a 120 and just cut it to length
I take it this is a new set of sprockets with a gearing you never tried before?
otherwise you would just count the links on the chain that is on there no right ;)
-1997 KDX 220 project bike
- Postigo
Re: Chain question
+1 as diy said you can go wrong with a 120 and it cost almost the same.diymirage wrote:cant go wrong with a 120 and just cut it to length
- KDXohio
Re: Chain question
+2Postigo wrote:+1 as diy said you can go wrong with a 120 and it cost almost the same.diymirage wrote:cant go wrong with a 120 and just cut it to length
- rbates9
Chain question
Or you can get a 130 or so and an extra master link and make your wife a nice bracelet with the extra chain.
