Postigo wrote:Its possible! If you learn to ride chainsaws. lol
Careful what you wish for.........
There's only 24 now if only they were STIHL'sdiymirage wrote:her one arm must be so much bigger then the other
having to pull start all those engines
Just so I understand you right, Pro Taper fat bars are much better then cheap knock off bars? I never would have guessed that...diymirage wrote:
It is my opinion that fatbars have a lot more strength then regular bars
now, I don't think ive ever had name brand 7/8th bars but some of the ones I had were thickwalled aluminum and they did not compare to the pro tapers
rbates9 wrote:Just so I understand you right, Pro Taper fat bars are much better then cheap knock off bars? I never would have guessed that...diymirage wrote:
KDXohio wrote:rbates9 wrote:Just so I understand you right, Pro Taper fat bars are much better then cheap knock off bars? I never would have guessed that...diymirage wrote:
Thats like comparing harbor freight to snap-on
If you have the factory (or aftermarket) carbon steel bars and you are going to go to the trouble to replace them, then you should at least spend the extra $20 or so and get a set of aluminum bars. The steel bars can bend even in just a minor tip-over as you seem to have found out. The aluminum bars are much more durable and capable of surviving some pretty large impacts. A set of aluminum hand guards will also add some strength.Well I dumped my bike, and the handlebars are a little tweaked. Barely noticeable, but I notice.
I did a small write-up in the injuries thread about the wipe-out. Nothing serious.
I reckon I wanna get new bars. That should be easy to do right?
Plus I was considering some of those guards I see on some of your bikes. The ones that look like they are designed to protect the controls if the bike goes down?
Any concerns or things I should know about before I attempt to swap handle bars out?
Thanks folks.
the bars bolt unto the triples by 2 sets of caps2 Wheels wrote:I want a near exact replacement of the bars I have now.
Where's these rubber cones you guys are talking about?
+1.rbates9 wrote: I would never consider using the aluminum cones in place of the rubber. They are there for a reason. They reduce vibration and give flex to the bars in a crash.
