1990 KDX
Has thanked: 153 times
Been thanked: 38 times
Re: 1990 KDX
I don't know which brake years will fit.
I just try to buy it all from the same year.
KDXohio
Re: 1990 KDX
Post by KDXohio »
Alright so I've been real busy lately haven't had much time to do anything but I finally got everything figure out and conversion done!
Here's some pics....they're prior to putting together the brake
Re: 1990 KDX
Hey, that looks great. Good job on it. It took me a second to realize they were not the stock forks. :partyman:
Would you mind taking and posting a few pictures of the silencer? I'd like to see that.
Thanks.
KDXohio
Re: 1990 KDX
Post by KDXohio »
By request here's the Answer silencer/spark arrest-or I snapped a couple pics I didn't have time to pull the cover did it on my lunch break (bikes unfortunately not stored at my apartment)
Re: 1990 KDX
THANK YOU!! I can't remember ever seeing the Answer VFC from those angles. I am a big fan of the old Answer silencers and spark arrestors. I liked all the ads in the mid to late 80's. :boogie:
I got an Answer S/A-Pro for my 1987.
KDXohio
Re: 1990 KDX
Post by KDXohio »
This is my first answer product it came with the bike when I picked it up. It sounds great not loud at all which I love I'm used to pro-circuit and DG silencers which can be very loud. I do want to know a little more about it. In the end Is a washer/valve that moves in and out I'm interested in what its intended to do is it for sound, flow/back pressure or is it simply for spark arresting? I haven't tried researching yet been wondering for awhile though.
Re: 1990 KDX
I am not sure what the part is for. Interesting! :hmm:
KDXohio
Re: 1990 KDX
Post by KDXohio »
Well I finally got to take her out to the trails yesterday with the new front end instead of putting around the house. HUGE improvement I feel like I'm floating through the trails I can run through at a much faster pace comfortably. I put it through everything, mud, rock, tree roots, hills with a mixture of the above and high speed straightaways with very uneven terrain the front tire glided over all of it I never would have been able to run those straights that fast with the old forks I would do this conversion again in a heartbeat! I'm extremely pleased.
Re: 1990 KDX
Thanks for the report. You sound like several I have heard.
Did you ever try to modify the stock forks any to suit your weight and riding style?
KDXohio
Re: 1990 KDX
Post by KDXohio »
Jason wrote:Did you ever try to modify the stock forks any to suit your weight and riding style?
The only modification I did was try different weight oils and levels. I did spend less than 150 on the swap, so I'm happy. Also the dual piston caliper has been a nice change too.
Re: 1990 KDX
Wow. Thanks again for the information. I am glad it all worked out for you.
