Was having ish with my kickstarter. I would kick and it would miss and grind. I replaced the spring, 2 washers and circlip on back of mechanism because they were not there. Threw it all back together, and it still does it! Except this time, you can hear the gear grinding while engine is turning over.
What parts could make it do this?
Dafuq is going on?!
- Has thanked: 15 times
- Been thanked: 28 times
Re: Dafuq is going on?!
The grinding when engine is turning over is usually the spring hitting the clutch basket because it's not correctly located in the keeper. The slip/miss is usually because the ratchet gear teeth are worn down, and do not catch consistently. There's your two "usual" answers. :)
- scheckaet
Dafuq is going on?!
which spring did you replace? the big yellow one (the one that returns the kick starter) or the very small one that engages the ratchet mechanism? If it slips, that's usually the culprit. you can take it and stretch it a bit if you don't have a new one on hand. it should engage better after that.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
ChrisZx7
So that plastic piece in middle of spring being worn, is causing spring to not sit properly and its rubbing on clutch basket. The ratchet gear doesnt look worn..Ill just replace anyways.
ChrisZx7
Dafuq is going on?!
I replaced the small one on back. Still slips.scheckaet wrote:which spring did you replace? the big yellow one (the one that returns the kick starter) or the very small one that engages the ratchet mechanism? If it slips, that's usually the culprit. you can take it and stretch it a bit if you don't have a new one on hand. it should engage better after that.
- scheckaet
Dafuq is going on?!
take apart and post pics.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- rbates9
That plastic collar can broaden your vocabulary when trying to get it all in place, correctly, long enough to get the cover back on.ChrisZx7 wrote:So that plastic piece in middle of spring being worn, is causing spring to not sit properly and its rubbing on clutch basket. The ratchet gear doesnt look worn..Ill just replace anyways.
- scheckaet
amen to that...
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
