Started rewinding my stator
diymirage
Re: Started rewinding my stator
Post by diymirage »
not sure man, but if you doubt the switch just bypass it, all you do is unplug the two wires from it and plug them into each other directly
-1997 KDX 220 project bike
90SDKDX
Post by 90SDKDX »
Yeah I've got my new switch wired up so I think i'm going to put the stator back in, kick it over, and see what happens. Don't know what else to do at this point.
90SDKDX
Post by 90SDKDX »
Well threw the stator in quick between jobs. Still no lights but I did notice I've got a red and black wire loose from the previous headlight so I may need to hook those up to power and ground and see if that helps.
90SDKDX
Post by 90SDKDX »
So I've got both my low, high beam, and tail/brake lights working. I ended up pulling the stator one last time, did a completely new rewind and that fixed it, along with a couple of hot wires that needed to be piggy backed into the harness. I really like the look of this trail tech X2 headlight. Thanks for trying to help. Now I can do ride tomorrow. :grin:
Jaguar
Country: Ecuador
Post by Jaguar »
According to the wiring diagram I am looking at, the coil wire goes to the regulator via the brown (or brown/red) wire and then to the bulbs. It's been a few years since I owned a KDX. I don't know if the coil is floating or is grounded. If it needs to be grounded and you forgot to make it that way then of course it won't work. A ground path would be the "return" path for the electrical current. I had the SR version of the KDX and it had a 40 watt resistor also that worked with the regulator. I don't know if the regular KDX has that resistor. If it breaks or is burned "open" then it screws everything up.
