91 KDX200 float height
I'm planning on cleaning my carb in my 91 KDX200 and I wanted to make sure the float what set right, does anybody know that stock height for it?
Re: 91 KDX200 float height
good question, I just set my 94 so that it shuts just before the floats are level. same as I would do with my hondas.
The manual says 16 +- 1mm. Here's a pic.
What does it mean by 16 + 1mm? I'm new to this
Look at the float height measurement section on that page. You want the number 4 measurement to be between 15 and 17 mm.
Follow the directions from that section and the note right below it and you will be fine.
I adjusted my float but still nothing. I sit there and kick and kick and kick. Sometimes it will spill gas out of the overflow tube from the carb. Think maybe a spark plug?
dirty valve needle?
Like, float needle? When I looked at it, it wasn't dirty. I cleaned the whole carb up and down.
It is the cone shaped, rubber tipped piece that is supposed to stop the flow of fuel into the bowl. A dirty/damaged bore or dirty/damaged rubber tip can cause a leak.
thank for the info. diagram is great help. scrambler if your getting gas to the carb u may want to check the plug. bill
