any light gurus out there ?
- diymirage
first off, the wiring on my KDX is a mess and should really be replaced
I am running a LED tail/brake light and that works
I am TRYING to run a headlight and it keeps blowing up
I hooked up a multimeter and with that set at 200 VAC it reads 8-9 volt at idle and as much as 28 when revving (the stator has been rewound)
I tried swapping out voltage regulators but the read out was the same
I know I SHOULD replace the wiring and go from there but in the mean time this is my daily driver and I would like to get some type of light going
any ideas ?
any ideas ?
-1997 KDX 220 project bike
- diymirage
rbates9 wrote:Find a better mechanic.
if I could find one that was affordable I would
- rbates9
Have you looked thru the wiring and made sure that everything is wired in the correct way and you don't have any broken wires?
- diymirage
Re: any light gurus out there ?
yes I did, best I can tell its all good
I even tore the tape off the main loom because I couldn't see where the brown one coming from the regulator went
(turned out it joins the red wire heading to the headlight switch)
now, I can get the headlight going, I just cant keep it going
as soon as I rev the bike the bulb will pop
Dekon
Not sure of what year you have, but my '89 didn't have a voltage regulator. Great design by Kawasaki, one light blows, the other one goes because of the voltage spike it gets. I think Kawasaki started putting them on the '90.
Oops, sorry, didn't see it mentioned in the previous post.
- diymirage
for what its worth it is 96
I tried 2 different voltage regulators both with the same read-out
- Has thanked: 160 times
- Been thanked: 40 times
stock headlight?
- diymirage
no, this bike has seen an array of different lightning set-ups
right now the head light is a KLX knockoff converted to H7
Roadhazardguy
Get a better voltage regulator, the ones that came on them weren't designed for that. On my atk I'm going to try a reg/ rec from a kawi 650 jet ski I have laying around, it should be good enough because the have multi pole stators.
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
Dekon
Just a thought, due to you running a LED tail light, is it not drawing as much voltage as a normal bulb and the therefore the headlight getting to much.
- Been thanked: 10 times
The quick answer is a more robust VR, but not really the correct answer. The KDX system is extremely simple, and is the reason that you see the lights pulse with the RPMs. Make sure all your grounds are really good and clean and then coat them with dielectric grease, goes for all the connections really. The correct fix is a small battery and a regulator/rectifier as RoadHazard suggests (ala Baja Designs). It is the only way you'll get clean, regulated 12 v out of our bikes.
- diymirage
rbates9 wrote:Have you looked thru the wiring and made sure that everything is wired in the correct way and you don't have any broken wires?
just had an epiphany, I have a second KDX sitting just a few feet from this one that does NOT have the same problem
so I went ahead and tore into that one and started comparing, this is what I found
wiring near the headlight on the bike without the problem
wiring near the headlight on the bike that keeps blowing bulbs
seems like the headlight isn't grounded out properly
I addressed the problem and restored the wiring to its original set-up and tried it out for a little while with a test bulb, so far, all is well
no time to play with it tonight since the wifey is graduating so ill have to go there, hopefully ill have an update tomorrow
You're diagram is missing the VR which should have a black/yellow wire to ground and a brown (if I remember correctly) to the red. The way you had it wired up is not a surprise you blew a few bulbs, wouldn't be surprised if it killed the VR as well.
- diymirage
the voltage regulator was wired in (like it shows in both drawings) but I didn't bother to color in those lines
if you think it fried it though (I don't know jack about electrical...I only know how to diagnose it : if you cant fix it with a hammer its an electrical problem) I could swap it out no problem with the one from the project bike
Thrahl
I'm not really an electricity expert so someone correct me if I'm wrong.
According to your drawings the problem bike had the headlight and taillight wired in series when they should be in parallel (like the working bike).
In series your lights are splitting the voltage (ie one gets 8 and the other 4 or something) but not the current. So your headlight was having too much current pass through it and blowing a bulb.
If it was hooked up this way (and you aren't mistaken with your drawing) when the headlight blows the taillight will shut off.
Hook it up in parallel and you should be good assuming the regulator didn't fry.
- ss109
- Has thanked: 30 times
- Been thanked: 47 times
That is the '89 schematic which doesn't show a VR as Kawasaki didn't install them until '90 and didn't update the manual. So, you say the VR is wired in like in the schematic but there isn't one in the schematic. I'm confused!
- diymirage
I guess I didn't catch that
I presumed it was part of the wiring I didn't bother color coding
so to rephrase that, the voltage regulator IS there and unmolested
Thral, I don't know what is going on, but when the front blows the tail stays on and the brake light stays operational
For future use and helpfulness...this problem is resolved?
The questions were correctly answered and would have taken care of the problem if followed, but the last input is, '...I don't know what is going on...'
What IS going on?
What IS going on?
- diymirage
what ever the black ground wire was was not essential as a grounb BUT it was essential in the voltage regulators workings
once I rewired it as shown in the first drawing (ground to the black which happens to be where the voltage regulator wires into) everything works as it should
to my previous "I don't know whats going on" statement, the blowing out of the headlight did NOT affect the tail or brake light, both of those have worked flawlessly
