Golden spectro 2-stroke oil. ??
- Ryan
hi, well im in search of a good oil for a kdx220. I can get golden spectro 2-stroke mix for like $6.00 in the 12oz container. I have just a few questions. Does this stuff burn clean and is it worth the money? Also, doesnt jeff use this stuff? And on the back it says normal ratio is 52:1, 64:1 for super technical, and 42:1 for rough terrain. WEll i tried 42:1 and it fouled my plug. I figured it was cause i had it jetted for 32:1. So i went back to that. The weird thing is my friend has his bike jetted for like 24:1 (its a kdx175). he tried this oil at 52:1 like the directions said and it ran great???
. He did not even rejett his bike. Well, should i try running 52:1 without rejetting?? Isnt this to lean? wont it burn out my motor? any help would be great?
- m0rie
I've been running Golden Spectro @ 52:1 since I got my 89. It always smoked and had a fair amount of spooge. I rejetted and reduced both and got the bike running much better but could never eliminate it completely. I ended up blaming it on the oil and just living with it because the bike ran like a champ. After I switched to a new RB'd carb and recorrected the jetting to work with it 99.9% of my excess spooge was gone. All I have now is a little dried ring at the S/A tip that can be wiped off after each ride. No drooling mess. So it would seem that my issues were not caused by lousy oil but lousy jetting.
-Maurice
-Maurice
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
AMSOIL. If your plug is fouling... it's jetted rich. It's not your oil and 52:1 is richer than 24:1.... more gas=richer!
- quailchaser
Indawoods wrote:52:1 is richer than 24:1.... more gas=richer!
Thank you!
I run Amsoil as well, but...there are many quality oils out there. The key is to CHOOSE A MIXTURE RATIO and then JET THE BIKE. Do not try and fix jetting by changing the fuel/oil ratio.
Robb
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
'02 KX250
PW80 for the Gman
AMA
Off Camber M/C
BRC
AZOHVC
Green Hornet
Yes, Fredette does use Golden Spectro. I asked him what ratio he uses and he replied 50:1, has for 20years.
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Green Hornet
I run Golden Spectro @ 40:1
Alot of other run the same ratio
Juat use a good quality oil
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
- fulltiltboogie
- KDXer
Green Hornet
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
If 52:1 you mean oil:gas... you got it backwards!
No wonder your fouling plugs.... I think Jason did that once...
Gas is gas...no matter if your talking about air or oil. Jetting is gas flow to air flow not the other way around. Don't make up for bad jetting with changing ratio's. Pick a ratio then jet for it... then you will be set. You will never get your jetting right if you keep changing ratio.
- Has thanked: 83 times
- Been thanked: 20 times
OK, pick on a 14 year old.
I ran my KDX80 at 64:1 thinking there were two ounces of oil per gallon of gas. OOPS! Just call me Gusher!!
Proly so...
kdx220freak, the 52:1 means 52 parts gas and one part oil. It is talking about the FUEL. If you went from 52:1 FUEL to 40:1 FUEL, then the FUEL is leaner. The LEANER / RICHER description is based on the amount of gasoline when one is talking about FUEL.
What people are saying is to choose which gasoline to oil ratio you want, then adjust your jetting properly. After you choose how rich or lean you want your fuel to be, THEN you choose how RICH or LEAN the engine is running. Assuming that the filter is cleaned and oiled properly, everything is in proper mechanical condition, etc., then THAT portion is controlled by adjusting the carburetor jetting.
There may havbe been some confusion on RICH and LEAN, as it relates to FUEL and how it relates to how the ENGINE is running. It took me a long time to figure out what everyone was meaning on "rich" and "lean".
I hope this helps.
I hope this helps.
OK, sounds good.
I know some have done it fine, but I am scared of 5X:1.
