low end bog!!
kdxquebec
Post by kdxquebec »
thanks all! tonight.....
I will re-flush the gas and I will buy new gas from an other compagny to be safe.
I will re-clean the carburettor and check pilot circuit and air srew passage.
Then if the bike do not runs fine,i will check for air leaks from reed to air filter.(wd40)
Then if the bike do not runs fine again I will look for a crankseal leak.
I will post results later tonight :sad:
Has thanked: 155 times
Been thanked: 38 times
Good luck with it! That sounds good to do one at a time, so you know what it was that was wrong.
kdxquebec
Post by kdxquebec »
ok
This was my first carb cleaning since I was born.
Yesterday I did not clean the carb correctly.
I found the pilot jet clogged today. and cleaned it with a needle and air.
I filled the tank with new premix and went for a test ride. (30min)
When I snap the throttle the front fender want to look the sky again!
The bog is gone and now I will spend time to set the air screw correctly.
Many thanks to jason.charley,vince.maurice... :razz:
I hope it will last.
My bike is alive now. thanks phil :partyman:
Indawoods
Creator and Founder
Creator and Founder
Post by Indawoods »
:supz: :supz: :supz:
GREAT NEWS!! Congratulations on getting it fixed.
m0rie
Post by m0rie »
Glad you got if fixed. Keep us posted if you have anymore problems.
-Maurice
1989 KDX 200
2007 TTR-50E
kdxquebec
Post by kdxquebec »
ok
thanks!
As I said I hope it will last!
By the end of the week I will replace the water pump seal and add the second seal mod like in the 91 model.I will also repalce the clutch pusher seal (the one on the clutch cover)
bye
phil
