What forks for 96 kx 500 triple tree
I got a complete triple clamp set up off a 96 kx 500. Now I'm looking for forks for them anybody know what ones I can use in these. Even different manufactures this way it will open up my options.
- dude541
Re: What forks for 96 kx 500 triple tree
if its a 96 it should be for 43mm forks.
91-94 kx125-250 will fit.
if you get 94's you will be able to use your kdx caliper.
best regards
john
best regards
john
The clamps clamp onto the outer tubes, not the 43mm inner tubes.
1991 - 1995 KX125
1991 - 1995 KX250
1991 - 1996 KX500
The outer tubes of those forks have the same outer diameters.
1991 - 1995 KX125
1991 - 1995 KX250
1991 - 1996 KX500
- dude541
I am sure most people know where to measure the forks from, and how they fitJason wrote:The clamps clamp onto the outer tubes, not the 43mm inner tubes.
1991 - 1995 KX125
1991 - 1995 KX250
1991 - 1996 KX500
if we need to be technical , outer tube sizes......upper 52mm........lower 56.6mm.
my previous quote about the caliper, I have just noticed you have a 89 200, so you would need to get a suitable caliper also, axle and wheel to would be easiest.
best regards
john
The later forks with 46mm inner tubes do have different outer tube dimensions for a few different years.
- dude541
correct for the 125 & 250, 46mm kx500 stayed the same size throughout the years 97-2004.Jason wrote:The later forks with 46mm inner tubes do have different outer tube dimensions for a few different years.
best regards
john
Thanks, this will help in my search for forks, gives me a little wider range to choose from. Then the search for front wheel and axle will start, this will be a piece at a time project when I have the extra money for it.
- CoronasAndChips
I have an ENTIRE 1991 KX 250 front end that will bolt right on. I had it on my bike for a week (2002 kdx 200) comes with everything except MC and line. It will need seals though. Where do you live here in Michigan?
Elbow grease contains no trans fat!
CoronasAndChips on XBox Live
BFBC2, BF3, COD 2,3,4, Black Ops, Red Dead Redemption, Tiger Woods 08' and 09' and Forza 2..... mostly
I live in Fenton, about 15 miles south of flint. I would be interested in it but money's tight right now.
