95 KX forks in 95 KDX 200
- rbates9
Even if they have the same internals as the KDX forks you will at least be loosing the underhang. That's a plus. Do those forks have compression and rebound adjustments?
Good to know. They are in good condition I'm just bummed they are not what the seller made me believe they were.Julien D wrote:They will be a considerable improvement, provided they are in proper condition.
They have the adjustments and they are working. It's good to know that at least I did not waste money on them.rbates9 wrote:Even if they have the same internals as the KDX forks you will at least be loosing the underhang. That's a plus. Do those forks have compression and rebound adjustments?
Thanks for the help guys.
1995 KDX 200
a little off the subject here is a linkage arm I made since my stock broke.
Moving on, I got the front end assembled today. It`s looking good, but I`m having some trouble with the brake caliper. Gonna have to postpone the test drive until next weekend.
The spacer in bottom clamp
Spacer in the axle. In this photo it is mounted in the wrong side of the hub. I actually had to put it in the other side to center the wheel in the forks.
1995 KDX 200
- rbates9
Looks like you will need to build up those steering stops before your done.
Yes I do. I was thinking about adding a little steel square spacer under the stop in the frame, drill the stop and add a little bolt to hold it together.rbates9 wrote:Looks like you will need to build up those steering stops before your done.
I just got the fork guards and some stickers to go with them. I'll need to work on them to add a holder to keep the brake line in position.
Probably tomorrow I'll put it all together an take new pictures.
1995 KDX 200
It`s done!! The bike is up and running. Tomorrow I`m gonna hit the trails and see how everything goes!
1995 KDX 200
Re: 95 KX forks in 95 KDX 200
Went for a test-drive today and this thing rocks!! Much more traction on the front, no slips and better feeling all around!
I get a lot more feedback from the front wheel and much less vibrations when going through big rocks or loose gravel conditions.
Anyone that is still doubtful about conversion, I can say that I was a skeptic, and now I`m thinking why I didn`t do this earlier.
1995 KDX 200
- 6 Riders
What was your final set up for the front wheel? Swap out a KX wheel, machine the axle?
I used the KDX wheel, hub and axle. I found that these were 1993 KX 500 forks. The only mods that were necessary were: a new spacer, (pictured in this thread) that I used in tandem with the KDX spacer on the break side of the hub (Can upload a picture later if you want); and a round nut that I machined to fit the forks, since in the KDX the axle screwed into the forks and in the KX it is bolted in the forks.6 Riders wrote:What was your final set up for the front wheel? Swap out a KX wheel, machine the axle?
If none of that made sense I`ll upload some pictures in the weekend and clear everything out.
1995 KDX 200
