04 kdx 220 ring gap
steve2
04 kdx 220 ring gap
Looking to install a new wiseco piston in a 220 ,what should the ring gap be and are the upper and lower the same ? They are saying .004 per inch of bore. Thanks
- Has thanked: 9 times
- Been thanked: 17 times
Re: 04 kdx 220 ring gap
Hello, Steve. Welcome to KDXRIDER! If you're doing work on the bike yourself, I highly recommend a service manual. We have a link to the cyclepedia version on our homepage which is subscription based. A one year subscription is all you'd need, and just make sure you've printed the entire manual before your subscription runs out. Factory service manual is fine as well, which can be purchased through Kawasaki. Either one will answer this, as well as the many other questions you will need answers to, such as torque specs, cylinder to piston clearance, KIPS timing, etc. In the meantime, I am at work currently and do not have access to my manuals. When I get home I can check and post up the ring gap specs for you if nobody has already gotten it by then.
J.
J.
- ICRage42
04 kdx 220 ring gap
sorry if asked before is the cyclopedia one better then manual ....I have the manual just asking. Thx.
If you already have a service manual, no reason to jump for the cyclepedia version. The best thing about it is the detailed color photos.
Sorry, I was out late and pretty hammered. I'll give it another try after work...
Piston/Cylinder Service Specs KDX220
Cylinder service limit: No more than 69.1mm
Piston-cylinder clearance: .095-.105mm
Piston diameter: No less than 68.8mm
Ring to Groove Clearance (Top and bottom): No more than .18mm
Ring End Gap (Top and bottom): .3mm to .5mm, service limit .8mm
