Scored 2 KX 250 80% complete bikes
- CoronasAndChips
The first one is a 1997 missing top end, exhaust, carb and fuel tank. The second is a 1991 missing seat, left hand engine case but came with a newly sleeved jug ( still has the honing marks ) three carbs and a new wiseco piston and topend gasket set. . Which front end is better for the conversion for my 2002 KDX?
The 97' front end doesn't have the disc or fork guards they do look as they would accept the ones off of the 91 maybe?
Elbow grease contains no trans fat!
CoronasAndChips on XBox Live
BFBC2, BF3, COD 2,3,4, Black Ops, Red Dead Redemption, Tiger Woods 08' and 09' and Forza 2..... mostly
- dude541
your 91 250 yokes have the same part number as the 91-93 kx500,so really it should bolt straight in!CoronasAndChips wrote:The first one is a 1997 missing top end, exhaust, carb and fuel tank. The second is a 1991 missing seat, left hand engine case but came with a newly sleeved jug ( still has the honing marks ) three carbs and a new wiseco piston and topend gasket set. . Which front end is better for the conversion for my 2002 KDX?
best regards
john
- doctord23
Re: Scored 2 KX 250 80% complete bikes
I believe that the 97's should be 46mm units while the 91's should be 43mm.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
- dude541
correct,doctord23 wrote:I believe that the 97's should be 46mm units while the 91's should be 43mm.
the 97 forks may be better? but the 91 set up he has will bolt straight in,where the 97 setup will need stems changing + extra bits & bobs etc.
depends how much work he is willing to put into it really.
best regards
john
- CoronasAndChips
Thanks for the quick replies. The 91's are the same tube diameter as my 2002. The 97 looks much more impressive but one of the axle cover studs are broke off at the outside of the cover. I also think those bigger forks might be overkill for the 200.
- Has thanked: 103 times
- Been thanked: 26 times
You can buy a 6mm x 22mm stud to replace the broken one.
There was an old thread on here from 2005 or so about the part number.
Please note that the stud is 6mm in diameter and sticks out 22mm. It is not 22mm long.
- rbates9
CoronasAndChips wrote:I also think those bigger forks might be overkill for the 200.
Isn't that why most people replace the stock forks? Not that they are over kill but less flexible?
- CoronasAndChips
I've had some time to monkey around with the bikes. I pulled the axle cover that has the broken stud and turned the fork to see what what i had to work with. The fork leg just dropped down and there is "something" rattling around in there no resistance at all.rbates9 wrote:CoronasAndChips wrote:I also think those bigger forks might be overkill for the 200.![]()
- CoronasAndChips
Thanks, I found a thread with the part number. Now I just need to fix them and rebuild them.Jason wrote:You can buy a 6mm x 22mm stud to replace the broken one.
