Reed look good
terminatr
Reed look good
Post by terminatr »
Hi.
How do you know if the Reed Valve is worn and needs to be replaced?
I'm trying to figure out why my 220 sounds lean only when running at constant cruising speed.
I notice the reed gasket is seaping oil.
I've taken the reed out, and it looks good to my eyes. Nothing broken. Nothing chipped. Is it still possibly bad?
2001 KDX220
pumpguy
Been thanked: 2 times
Reed look good
Post by pumpguy »
If you mean oil is leaking OUT to atmosphere, that means you have a LEAK, which also means you have air LEAKING IN from atmosphere too. I would seal this leak and see what happens.
terminatr
Reed look good
Post by terminatr »
I try to take a picture tonight.
Around the Reed gasket, there's almost a lot of dirt attracted to it.
2001 KDX220
cornishwrecker220
Reed look good
Post by cornishwrecker220 »
spray some carb cleaner around the reed cage/carb intake boot whilst the bike is running..if you have a leak around this area then you will notice that the RPMs will increase.
rbates9
Reed look good
Post by rbates9 »
cornishwrecker220 wrote:spray some carb cleaner around the reed cage/carb intake boot whilst the bike is running..if you have a leak around this area then you will notice that the RPMs will increase.
+.5
If the leak is large enough the RPM's may go down. Like it is flooding. Or it is possible to have the RPM's go down with a very small leak due to the leak being temporarily plugged. What you should be looking for is a change in RPM's.
