need help finding a caliper
86kdxjake
Post by 86kdxjake »
I just got an 86 kdx 200 and the front caliper is missing. I tried looking it up on cheapcycles but it seems like they are all dicontinued. I was wondering if anyone has swapped on a newer caliper to the old forks or if any other bikes have a caliper that will bolt on without too much fabrication. Thanks Jake
dude541
Post by dude541 »
82-86 KX125, 83-86 KX250 KX500, 86-87 KDX200 will fit.
best regards
john
some on ebay.........
http://www.ebay.co.uk/itm/87-KAWASAKI-K ... 5d2f7d57ca
http://www.ebay.co.uk/itm/FRONT-BRAKE-C ... 58912cb952
diymirage
Re: need help finding a caliper
Post by diymirage »
dont know if it will fit but i have a 99 KX caliper for sale
let me know if you want to give it a shot
-1997 KDX 220 project bike
Roadhazardguy
Post by Roadhazardguy »
Tony
1988 KDX 200
1980 KD 80
1989 ATK 406
1984 RM 500
1980 KZ 1300
2008 SM450R
dude541
Post by dude541 »
diymirage wrote:dont know if it will fit but i have a 99 KX caliper for sale
wont fit,the 86 kdx200 has only a single piston.
best regards
john
86kdxjake
Post by 86kdxjake »
Has anyone tried making a bracket to mount one of the 2 piston calipers to the old forks?
I'd be eilling to try but I don't want to throw money away on a caliper that I may not be able to use.
On the plus side I got tge bike running with a new air filter and clhtch cable today. It would be nice to have front brakes though lol.
rbates9
Been thanked: 2 times
Post by rbates9 »
86kdxjake wrote:Has anyone tried making a bracket to mount one of the 2 piston calipers to the old forks?
I don't know if it will work, but if you want I have a caliper from a 2000 KX you can have for a donation to the site.
86kdxjake
Post by 86kdxjake »
I think I'll have to take you up on that offer
86kdxjake
Post by 86kdxjake »
I think I just found a caliper locally on cl
rbates9
Post by rbates9 »
Just let me know.
86kdxjake
Post by 86kdxjake »
I picked up the caliper today. Everthing seems right. I'll install it tomorrow and see how it works
86kdxjake
Post by 86kdxjake »
Mounted the caliper today but couldn't get it to bleed. I'm going to bring my mity-vac home from work tomorrow. Hopefully that will do it or I can bring it to work and use the power bleeder there but I think thats overkill
86kdxjake
Post by 86kdxjake »
Tried bleeding with the vacuum bleeder today. Still no luck. I might have to find one of those saringes to inject the fluid through th bleeder. Anyone know where to get one of those?
kdxtreme
Post by kdxtreme »
You can get them at a feed store if they still won't pump up zip tie the lever to the bar and leave overnight and the bubbles will rise on there own. good luck
Did I say riding?
rbates9
Post by rbates9 »
kdxtreme wrote:You can get them at a feed store if they still won't pump up zip tie the lever to the bar and leave overnight and the bubbles will rise on there own. good luck
This is a good tip. If you can get any kind of lever then I would try it.
Dekon
Post by Dekon »
KTM's are notorious for needing this. Someone told me KTM actual sells a clamp that goes over the lever and bar to keep the lever pulled.
86kdxjake
Post by 86kdxjake »
I'm striking out with getting fluid through this system. I might have to rebuild the master and caliper. Something just doesn't seem right. I've bled some pretty tough systems before but nothing like this thing
86kdxjake
Post by 86kdxjake »
I guess the threat of ripping it apart further worked lol. I tried bleeding one more time and all the air came out. The brake works great now
