does anyone have a pic of an odometer mounting they can post? someone gave me one and I can't seem to figure out how it bolts up,it came with a bracket.it's on a 95 200 model.
THANKS
kdx odometr pic any one?
cowboydfk
- rbates9
The bracket should come up the back side of the ODO then mount to the right side bar clamp bolts. On top of the clamp and under the bolt heads.
cowboydfk
I have pro taper bar's does this change things? also that would position it of to the one side opposed to the middle,does that sound right?
cowboydfk
I was out in the garage checking it out and looks like I need longer bolts because the one's I have now are rescessed into the hold down clamp but no big deal.Is it better to mount on the left or right side?how does it come factory?
- rbates9
rbates9 wrote:The bracket should come up the back side of the ODO then mount to the right side bar clamp bolts. On top of the clamp and under the bolt heads.
It probably doesn't matter but you will probably have more room to reset the odo on the right side because the reset knob is on the left side.
Also if your bolts are recessed then you will probably want to get some spacers to go under the bolts to fill in the gap between the clamp and the bolts.
cowboydfk
I got it all mounted,had to cut the square pad up a little but still looks good.Thanks for the info
