Low speed stumble
KDXNOOB
Low speed stumble
Post by KDXNOOB »
Hello everyone, first time post, got a new to me 04 KDX220, replaced the piston and kit with help from KDXRider, thanks everyone.
Now I need to troubleshoot a slow or low speed stumble.
Idle's good, but from just off idle to 1/4 throttle it has a stumble. By stumble I mean it doesn't run smooth and hesitates just a little. 1/4 to WOT it runs great. I have removed carb twice and cleaned, cleaned both jets with a small wire, tried adjusting pilot screw, no help.
It's completely stock, only mod I have done is remove the airbox tube, it has new plug, new piston and kit, it stumbled before piston and kit, it has stumbled sense I purchased from previous owner about 1 month ago.
Other question I had was is the stock air filter cleanable or throw away/replacement type. I looks stock, anyone recommend a K&N?
Any suggestions?
2004 KDX220
rbates9
Been thanked: 2 times
Low speed stumble
Post by rbates9 »
For the stumble you need to go thru the jetting procedure in the "Jets and needles" section. What is your current jetting? You will probably need to go down a size or two on the pilot.
As for the air cleaner it is cleanable if it is in good shape. Or you could get a new pre oiled filter for $15-$20.
As far as the K&N, do a search on here. There was a topic not too long ago that went over this, and over, and over, and over it. :lol:
ROADSTR6
Low speed stumble
Post by ROADSTR6 »
Sounds like a rich pilot jet. You may need to re-jet...especially if you are on the stock jets. For now, try turning out the air screw on the carb in 1/8 turn increments. You might find the happy spot that way.
