Replace fork seals
amstel78
Replace fork seals
Post by amstel78 »
I need to replace the fork seals on my bike and a local shop has quoted me $90 plus parts to do the job. I already have the seals and normally wouldn't mind attempting this job on my own but I don't have the specialized tools specified by the manual. Does the quoted price of $90 sound reasonable?
Sent from my SGH-T989 using Tapatalk 2
Has thanked: 15 times
Been thanked: 28 times
Re: Replace fork seals
I think it runs about $75 plus parts around here. Not terrible. The specialized tools can be fabricated pretty easily, if you decide to tackle it yourself.
scheckaet
Replace fork seals
Post by scheckaet »
I don't think the tool is absolutely necessary, I think I used super long flat screw driver to hold the piece is place (it's bee awhile though...)
Has thanked: 195 times
Been thanked: 52 times
Replace fork seals
Where is NEPA?? I will do it for Pizza Hut and Dr. Pepper. :grin:
amstel78
Replace fork seals
Post by amstel78 »
Jason wrote:Where is NEPA?? I will do it for Pizza Hut and Dr. Pepper. :grin:
LOL, I wish I could take you up on that offer. I'd even throw in a case of your favorite beer should you so desire. NEPA is short for North East Pennsylvania. You're a bit too far for a weekend road trip!
rbates9
Been thanked: 2 times
Replace fork seals
Post by rbates9 »
Im in upstate NY and would offer the same service - the Dr Pepper and + the Beer. :grin:
amstel78
Replace fork seals
Post by amstel78 »
rbates9 wrote:Im in upstate NY and would offer the same service - the Dr Pepper and + the Beer. :grin:
Where in NY are you exactly?
rbates9
Replace fork seals
Post by rbates9 »
About an hour north east of Albany. 5 miles from Vermont.
Replace fork seals
Oh well. Good luck on the rebuild. I am off to cook and pour my own drink. :grin:
amstel78
Replace fork seals
Post by amstel78 »
I've found a few 43mm fork drivers for under 40 bucks online, but am hesitant to spend 40 dollars on something that'll get used rarely. Any other suggestions as to what can be used to pound the fork seals back in without damaging them?
Dekon
Replace fork seals
Post by Dekon »
On my Beta, I used a piece of PVC pipe. I put the new seal on the fork, put the old seal on top of the new seal so I would not damage it and then used a piece of PVC pipe to drive it in. But, the Beta is a trials bike and the forks are of a much smaller diameter. Maybe you could find a piece of PVC that has the right diameter.
scheckaet
Replace fork seals
Post by scheckaet »
pvc pipe and old seal worked for me.
amstel78
Replace fork seals
Post by amstel78 »
Another question: the service manual states the fork takes 618ml or 20 oz of oil. Is that per damper or both?
amstel78
Replace fork seals
Post by amstel78 »
OK, one more question. The manual states that I have to remove the cylinder valve assembly when disassembling the forks. Is that absolutely necessary? That requires two special tools which I don't have. Can't I just remove the top bolt, remove the spring seat and spring, drain the oil, then proceed to separate the inner tube from the outer tube by first removing the dust cover then the snap ring??? :hmm:
amstel78
Post by amstel78 »
I take it from the lack of responses that the manual's correct in that I'll have to remove the valve assembly to get the damper apart? Sorry for so many questions, but sometimes the service manual isn't very clear.
Replace fork seals
Yes, you have to take the cartridges out before separating the tubes. Buy a 14mm hex socket and FRP Offroad cartridge tool.
Pour boiling water on the seal area before separating the tubes. You will WHACK the bushings to death (if they are not already shot), otherwise.
