Mud riding techniques
Have a question about technique?
Racing220
Post by Racing220 »
Has thanked: 15 times
Been thanked: 27 times
say what?
rbates9
Post by rbates9 »
Julien D wrote:say what?
+1
Racing220
Re: Mud riding techniques
Post by Racing220 »
What do I do when my bike gets no traction on mud, and just slides out, is it the trials tire I'm running?
rbates9
Post by rbates9 »
Trials tires and mud are not a good match. It is doable but if you are riding in mostly mud then it is time to put the knobby back on.
What trials tire and how much pressure are you running?
Racing220
Post by Racing220 »
Mt43 at 15 psi
Varmint
Post by Varmint »
Racing220 wrote:Mt43 at 15 psi
Way to high even for a knob. I run 11.5 in my knobs. I bet 8 or so on that trials tire might make a huge difference
In my garage
2003 KDX200
2003 KX85
2005 CRF230F
2009 300 XC-W(e)
My KDX
rbates9
Post by rbates9 »
+1
The MT43 is a stiffer trials tire so as long as your riding in mud then you could probably go even lower then 8 Psi. I would recommend getting a ultra heavy tube if you don't already have one. I use a Bridgestone UHD tube and have rode very rocky trails with 6 Psi and have not gotten a flat with my Michelin trials tire that is even softer then the MT43.
When I went to a trials tire I started at about 12 Psi and didn't understand what the hype was about. I let a pound or so out at a time until I realized what the hype was all about. I ended up down to about 8 Psi and haven't dented a rim or pinched a tube yet. But keep in mind that with a tire that soft in the back the handling will get washy at higher speeds.
Racing220
Post by Racing220 »
Well the problem I have is that on the trails in Colorado, it's been raining lately and it's only muddy in the shade, so is there a tire pressure in between?
rbates9
Post by rbates9 »
Go low..... Bring a hand pump if your concerned but a trial tire NEEDS to be soft to work. The traction from a trials tire is best with low pressure. Even on not muddy ground.
If you need to ride fast and need the traction in the mud then you need a knobby. If you are riding rocky trails with some mud and a few high speed runs then let the pressure down. 15 is WAY to high to get anything from a trials tire.
One thing I have found with a trials tire is that when you get in the mud don't think you will get traction. Just hold the throttle about 1/4 - 1/3 and let it get you thru. Excessive spinning will not help.
Exactly as above. Running over 10psi with that tire would only be needed if you are riding on asphalt. Try 6 - 8, and practice throttle control. I have no issues riding in mud my MT43, other than trying to stop quickly, lol.
kdxmaniac
Post by kdxmaniac »
i just try to stay ''AWAY'' from the mud. :rolleyes: .......ill cut thru the woods and make my own trail to stay out of the mud. less mud, less washing= more time to ride :lol:
my bikes
96 ktm 300
96 XR400R
07 hayabusa
77 kz 1000
85 goldwing 1200
02 BIG DOG PITBULL
gone but not forgotten
96 kdx 200
97 ktm 360
96 ktm 250
93 wr 250
94 dr 350s
93 kx 250
07 gsxr 1000
99 bandit 1200
rbates9
Post by rbates9 »
Julien D wrote:, other than trying to stop quickly, lol.
Now that is one MAJOR draw back of the trials tires that really sucks to find out first hand. :lol:
