KIPS valves
Dekon
KIPS valves
Quick question, while working on my bike today(E-1), my assistant(3 Y.O. son) pulled on the KIPS shaft and now, the left valve does not open.. When I took the exhaust off earlier, all of the KIPS valves worked. I am wondering if he pulled the shaft out to far and disengaged the valve. What do you think?
- ss109
- Has thanked: 34 times
- Been thanked: 57 times
Re: KIPS valves
Yeah, that's probably it. Just realign them like the manual says and you should be fine.
- Has thanked: 15 times
- Been thanked: 28 times
KIPS valves
The sub valves have gear teeth all the way around the shaft. No way to really "disengage" it, you could only throw it out of time. My guess is your helper found the bad spot on the gear teeth. Might want to pull them and have a good look.
- ss109
KIPS valves
True. I was assuming the head was probably off and not all the KIPS parts in place.Julien D wrote:The sub valves have gear teeth all the way around the shaft. No way to really "disengage" it, you could only throw it out of time. My guess is your helper found the bad spot on the gear teeth. Might want to pull them and have a good look.
KIPS valves
Correction. Does the idler gear have teeth all the way around? I'm thinking not. Can't remember off-hand. If the head was off, it's totally possible that the RH is out of time against the idler gear, and jammed up.
Dekon
KIPS valves
Well, I got the motor apart today. The left KIPS valve is toast. The shaft on the top is broken off and the gear is totally stripped. I don't think my son did that. On another note, it looks as if the motor was rebuilt before I bought it. There was very, very little carbon on the piston crown, it looks brand new. That might be reason why there was an E-2 head on it. BTW, what do you guys use to clean the KIPS shaft, valves, and resonator with?
