Trans oil disappearance
terminatr
Post by terminatr »
Hi. I have to refill the trans oil after a few hours of riding. The oil level will go from top of the mark on the sight glass to the bottom after a few hours of riding. I don't see any oil leak anywhere. I suspect that the culprit is crank seal because there's alot of splooge on the muffler and the bike has been running blublury.
I want to replace the piston and rings. I figure that I'll check the crank seal while I'm at it. But from what I've been reading, crank seal replacement is a monumental task. So, I'm getting scared.
Question: How much should bike shop charge for new piston, rings, and a crank seal?
Is this something any bike mechanic can do? Or do I have to take it back Kawasaki?
Thanks!
2001 KDX220
sped66
Post by sped66 »
Any competent bike mechanic can do it. Labor prices vary. Ask your local riders who they recommend.
In the stable: '00 KDX220R, '02 XR250R
Gone but not forgotten: '80 XR80, '87 XR200R, '94 KDX250, '01 YZ426F, '86 XR220R
rbates9
Post by rbates9 »
Any GOOD bike shop should be able to do it and charge a lot more than it should cost. But it is not that bad to do your self.
sped66
Post by sped66 »
I'm lucky. My mechanic works for cheap & does a good job. I leave the more time consuming stuff to him.
osobad
Post by osobad »
take the motor out of the bike and take head and jug off. Clutch side componets and flywheel. have shop split case and put new seals and crank bearings. By disasembling down to case you can save half the cost
Fieldie
Post by Fieldie »
Mine has just started losing oil too - plenty of smoke, burbling on start up...
I had just switched trans oil to 2 parts ATF & 1 part SAE 15-40 engine oil.
I am going to switch back to gear oil to see if I still lose out. Will that help?
1997 KDX200-H3 Stock Standard except FMF Fatty pipe
...the glass is always half full...
david
Country: UNITED STATES
Post by david »
Gear oil? As in 80w-90? That can't be good for the clutch plates.
'81 KDX 175
'90 KDX 200
'82 Honda GL500 (sold)
'96 ZXi 1100 JetSki
'98 STX 1100 JetSki
Fieldie
Post by Fieldie »
david wrote:Gear oil? As in 80w-90? That can't be good for the clutch plates.
Sorry David, back to straight oil, no ATF...
Has thanked: 10 times
Been thanked: 17 times
Re: Trans oil disappearance
I wouldn't think mixing motor oil and ATF would be a good idea. Gear oil is less than ideal also, but better than some things you could be using. Regardless of what you are running in the transmission, you should not be losing transmission oil. It's either leaking it or burning it.
