Restoring plastics?
kyledsmith87
Restoring plastics?
Post by kyledsmith87 »
Anyone had any luck restoring their old KDX plastics to their former luster? How?
Mr. Wibbens
Restoring plastics?
Post by Mr. Wibbens »
wet dry sand paper and mop and glo
can also use a heat gun
google it, there's info out there
Thrahl
Restoring plastics?
Post by Thrahl »
I have used the razor blade and heat gun method to some success.
It takes a long time and it is difficult to get small nooks and crannies without gouging up the plastic real bad, but it will look pretty good in the end and is a lot better than paying for new plastics.
Has thanked: 15 times
Been thanked: 28 times
Restoring plastics?
I did the wet/dry sandpaper on my tank, from 600 - 1500 grit, and then polished with mop n glo. Turned out pretty good.
LTOWNKDXER
Restoring plastics?
Post by LTOWNKDXER »
I ALSO FOUND OUT CLEAR COAT AFTER WET SANDING LOOKS AWESOME! TROUBLE IS DOESNT LAST LONG BEFORE YOU HAVE TO DO IT AGAIN, BUT MAN IT WILL LOOK BRAND NEW FOR A WHILE!!
REMEMBER IF YOU AREN'T SCARED, THEN YOU AREN' T RIDING FAST ENOUGH!!! BY THE WAY ,THEY PELTED US WITH ROCKS AND GARBAGE!!!
rbates9
Been thanked: 2 times
Restoring plastics?
Post by rbates9 »
LTOWNKDXER wrote:I ALSO FOUND OUT CLEAR COAT AFTER WET SANDING LOOKS AWESOME! TROUBLE IS DOESNT LAST LONG BEFORE YOU HAVE TO DO IT AGAIN, BUT MAN IT WILL LOOK BRAND NEW FOR A WHILE!!
No need to yell. We can hear you just fine.
LTOWNKDXER
Restoring plastics?
Sorry about the caps.
