Adding pre-load to factory USD?
kyledsmith87
Post by kyledsmith87 »
Has anyone found a decent way of adding pre-load to the USD KDX forks? Spacer between the spring and cap or something?
Has thanked: 195 times
Been thanked: 52 times
Which model forks are you referring to? The KDX200 has too much, and the KDX250 is just about right. I would say no more is needed. Stiffer springs may be needed, but not more preload.
kyledsmith87
Just managed to win some .39kg springs off ebay!
Which brand springs are they? Are they for the KDX200 or 250?
kyledsmith87
1991 KX250 USD springs
kyledsmith87
just done a million checks and there is a rather large chance they wont with as the kx is 43mm and kdx USD is 41mm... p00p
No. They won't work. The outer diameter is too large. Sorry.
kyledsmith87
Re: Adding pre-load to factory USD?
Back on the 'bay they go! Anyone know of any 41mm springs that work at all?
Been thanked: 19 times
Just hit up RaceTech's catalog.
Springs from FRP or Race Tech were the only ones I found to work. I suggest going with the Race Tech springs.
