surging idle
turner
surging idle
hey guys sometimes when i pull over at the side of a trail and pull the clutch in, my 2003 kdx 200 sounds funny. my friend says it is a lean surge cause it goes wah wah wah wah. i have a 48 pilot, 2nd clip needle and 160 main jet. also when i rev it in neutral the engine still spins pretty high for a second or two. the bike has an fmf gnarly pipe and sielencer and removed airbox. does anyone know any solutions to this or is this a normal thing to happen?
Fletch
surging idle
I'll second that and also add to check you're float height and needle and seat condition. That's pretty fat stock jetting. With a new top end I'm running a 48 like you and a 158. I'm still rich but don't foul plugs. My bike did the exact same thing but my needle seat combo was letting in too much fuel and screwing the float height up.factoryX wrote:Whats the plug look like?
Fletch
89 kdx 200 with 99 rm125 forks
turner
surging idle
i measured the float hight when th ecar was of and it was at 17mm, so its in tolerance. i havent fould a plug yet but ill try and check my inlet needle tomorrow.
Fletch
surging idle
your friend could be right, you should do a plug chop or two and see what's going on in there...turner wrote:i measured the float hight when th ecar was of and it was at 17mm, so its in tolerance. i havent fould a plug yet but ill try and check my inlet needle tomorrow.
Fletch
- Has thanked: 13 times
- Been thanked: 26 times
surging idle
Lean condition doesn't quite fit in with the jet sizes you've listed. I would suspect an air leak.
turner
surging idle
yeah i repacked my sielencer and after riding saturday, sploog has dripped down again. i am going to order some 155 and 45 jets tonight. I ride at 1700' so hopefully theyll be better.
- fuzzy
surging idle
Ditto what juliend said. You can check with spray of water, WD, etc spray all around intake/exh etc and see if idle changes(stabilizes).
'91 KDX 200 Project $300 KDX
'95 KDX 200 Project $600 KDX
'94 WR 250 Always a project
