Lighting coil
computerguy50
Lighting coil
Post by computerguy50 »
Just read Indawoods "best mods sticky" he mentions a stronger lighting coil will excite/boost the bike performance slightly. Everybody agree? Does it help low RPM or high RPM or everywhere?
Does anyone have a link to the recomended one?
factoryX
Post by factoryX »
Its so you can run a better headlight. The upgrade is sort of in the name..
computerguy50
I do understand the main purpose would be to support higher wattage lighting, but it read like there was a benefit to the engine ignition too. Sounds like you disagree.
KarlP
Post by KarlP »
I also understood from those guys that it did in fact improve performance slightly. I wasn't clear on if it was a flywheel effect or an ignition effect.
Look at some old posts from canyoncarvr, I think he investigated it pretty thoroughly.
'08 KTM200xc
KX100 for the boy
paulkdx220
Post by paulkdx220 »
i don't think it's going to affect the ignition. the ignition uses it's own dedicated pick-up coil.
i have a steahly 65w stator with an stock headlight and it makes it much brighter, as it's supplying the headlight with the full rated wattage unlike the stock stator. i was slightly brighter than my buddy's baja designs equipped xr650
Been thanked: 19 times
When I made my 100W stator, I noticed a more "crisp" bottom end. I have no evidence that quantifies this other than my "butt dyno" but I did notice a small difference.
diymirage
Post by diymirage »
Slick_Nick wrote:When I made my 100W stator, I noticed a more "crisp" bottom end. I have no evidence that quantifies this other than my "butt dyno" but I did notice a small difference.
i dont suppose you'd wanna make me one would you ?
I wouldn't mind at all. You'd have to sebd me your stock coil, and I could rewind it for you.
diymirage
Post by diymirage »
sweet
ill see if i can find an extra stocker to send your way so i wont have any downtime and you dont have any pressure to get it all done :)
what is the price of your services?
-1997 KDX 220 project bike
I'd say whatever the wire costs, say $60 should be sufficient to cover my time.
