Aftermarket PIPES
asmed12345
Aftermarket PIPES
Post by asmed12345 »
Would an after market pipe (i.e. fmf gnarly etc) work fine with the stock silencerr or would I have to do something to mod them. Also, does anyone make a pipe the same color as the silencer and stock pipe?
'96 XR 100 ''02 KDX 200
Has thanked: 9 times
Been thanked: 17 times
most aftermarket pipes are plated. The stock silencer will work fine with any aftermarket pipe.
diymirage
Post by diymirage »
but i would expect you could get a can of high temp flat black paint at just about any hardware store right?
according to the sticky on mods there is no real gain in replacing the stock silencer
-1997 KDX 220 project bike
rbates9
Post by rbates9 »
If you went with using a high temp paint on a plated pipe it would probably fall off pretty quick unless you sand blasted the plating off. Maybe stove polish would take the heat better than a high temp paint but I think you would still need to remove the plating.
