hello, new to the forum, new to trail riding and new to an '01 kdx220 (this is my 1st season)
i love this bike, i love 2 strokes (i own a '75 kawasaki h1 street bike)...
so, i'll cut to the chase...
can i get a brighter stock headlight by simply upgrading the stator to higher wattage and then solder a jumper across the stock bulb contacts to make use of both filaments simultaneously? i understand that a single filament is 30 w approx.
who sells the biggest stator coil in terms of wattage?
i prefer the look of my stock headlight and number plate.
thanks,
paul
do HID kit's work on a stock headlight fixture and will it run off of AC current?
new kdx guy here... lighting question
paulkdx220
- scheckaet
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
paulkdx220
i've started to read it. there's some really good info there. that's sort of how we test aircraft alternators at my previous work, except we use a test stand. the method is the same. keep applying loads until the voltage drops to about 13-ish volts and read off the amperage at that moment and compare to the specs.
i think my original statement is incorrect in thinking that i'll get more light by jumping the two 30w filaments of the orig. bulb with a beefed up stator.
is there a headlight bulb out there that will fit into the stock headlight socket that is higher than 30w?
Engineer5
Here's a place that sells an upgraded stator.....http://www.steahlyoffroad.com/lighting/ ... -coil.html.
Like you I'd also like to keep the stock look to my light but find a more powerful bulb.
"Fathom the hypocrisy of a Government that requires every citizen to prove they are insured...but not everyone must prove they are a citizen."
paulkdx220
i liked that stator, i was close to buying it. however rewinding it myself seemed like a good option too. maybe i'll just get it seeing as free time is a bit scarce.Engineer5 wrote:Here's a place that sells an upgraded stator.....http://www.steahlyoffroad.com/lighting/ ... -coil.html.
do HID headlights and led tail lights work on our a/c systems somehow? if so is there a good system that fits up to our bikes that recommended?
