1993 Kdx 250 forks
greenpickle
1993 Kdx 250 forks
S'up guys, after changing out my fork seals and bushings, I gotta fill em back up. People say to use mobil 1 atf, any thoughts? Also, Im not sure how to fill em back up, or how much to put in them. Any thoughts would be much appreciated!!!
Always looking for 1993 KDX 250 parts!
- KDX Butterfly
- Queen B
greenpickle
- Rick
This needs to be in the "General Question" section, and not here. You will get answers there!
Yes, they really do let me drive the Train!
1991 KDX 250 $Sold but not forgotten....
1996 Suzuki DR 350 $Sold!
2002 Honda CR 250 worth more than my house at this point........ :-)
2004 DR 650se Road Warrior
2002 DL1000 V-STROM
2002 DL1000 V-STROM
- ss109
- Has thanked: 30 times
- Been thanked: 46 times
Mobil 1 ATF will be fine.
Specs from the manual say stock oil level is 95mm with an acceptable range of 80 to 130mm. Actually adding the oil and measuring it is the same as any other bike. Check Youtube for some videos showing how it's done.
- Velocity_Stack
- KDX Butterfly
- Queen B
- Has thanked: 10 times
- Been thanked: 17 times
Moved to general Q&A.
Fork oil is not measured in volume, but in MM from the top of the fork tube. This is fork collapsed, springs installed. I run 110mm, but anything from 90 - 120 should be fine depending on your riding style. Normally people over-fill, then bleed the air out, then suck out the excess using a tube that is marked at the proper distance. Put a syringe or something in the end of a clear piece of tubing, mark the tubing at the correct distance, hold mark at top of fork tube, suck out excess. Done.
Hold up, that should read "fork collapsed, springs removed".
greenpickle
