KDX 220 high revs on starup
jubby
Hi all, my kdx220 has started reving really fast when started from cold, as though it is running at about half throttle. It then settles down to a normal idle after a couple of minutes or a short ride. It only does tis when cold, all other times it is fine. Throttle is not sticking and I have had carb apart and all seems fine. What am I missing? All help very much appreciated.
- Mr. Wibbens
Mine used to do that really bad. Never did figure out why
I'd just have to remember at the end of the day to turn the idle screw way out
The warmer the bike got the lower the idle would get, by the end of the day I'd have the idle screw turned all the way in
KDXrider1989
kawie
my kx250 does this also.its not the reeds or carb or air leak it just the way it is.what i found out was to lean bike over an twist throtle till gas runs out vent tube,then i slowly kick the bike over 5-10 times without starting it.then i give it one good kick an it starts right up with no high rev.i think with my bike that there is not any or enough fuel through the motor to run right an if i slowly kick it it charges the cylinder with gas mixture instead of high rev like when it runnig out of gas.
try it this way an see if it makes a difference for you.
Kawie
Kawie
2004 kx125
2001 kdx220
2000 kx250
1996 kx250
2001 kdx220
2000 kx250
1996 kx250
- rbates9
- Been thanked: 2 times
I have not noticed the high revving thing but with mine if you just turn the gas on and start kicking it takes several kicks to get it to start, but if you turn the gas on and walk away for a little bit then it will start on the first kick every time.
It might be something to do with the bowl being empty and leaning it out until it stabilizes?
