Solved the powerband issue.... almost
KDXrider1989
Post by KDXrider1989 »
Decided to take off the exhaust and look into the cylinder to see if all the valves matched up. They did, but I noticed how the governor shaft was out of the collar that pulls open the KIPS
The shaft moves up and down easily, is that normal? This explains why the power comes on and off whenever I go over rough terrain, because the shaft slides in and out of that collar. Any way I could fix this?
Has thanked: 15 times
Been thanked: 28 times
I made a plate that goes over the whole mess with a hole drilled for that bushing and one where the set screw goes. Seems to have fixed the problem you describe.
KDXrider1989
Do you have a picture of the plate you made? I might make one myself if I can't fix this problem
No, but I guess I should. Someone else asked for one too. It's nothing pretty, just a piece of flat aluminum with 2 holes drilled in it.
Has thanked: 34 times
Been thanked: 57 times
juliend wrote:Someone else asked for one too.
Yeah, I have been waiting. :evil:
:mrgreen:
dfeckel
Post by dfeckel »
Me too! ;)
However, you've described it enough that I'm pretty sure I know what it looks like already.
David Eckel
KDXrider1989
Problem fixed! Went to Ace Hardware and picked up a dowel pin that fit inside the hole and groove on the governor shaft and put the bolt back on. I think I need new handlebar grips now :lol:
