top end noises
Tedh98
Post by Tedh98 »
Does the noise change/vary with the speed of the bike or engine RPM?
Do you hear the noise at idle? If you are at idle in neutral, does the noise change when you pull in the clutch?
How did you blow the engine?
05hybridchick923
Post by 05hybridchick923 »
I was riding it yesturday on some of the gravel roads by the house was revved pretty good so i would say high rpms it made the noise in 5th and 6th gears i down shifted gave it gas and it did it again shifted back up and it did it, havent had the bike long, I was told that wide open all the time is not good on a 2 stroke so wont be doing anymore back roads riding,
the rest of the time riding it it sounds fine other than the normal tap im used to hearing,
as far as blowing it up not sure exactly how i did it i cracked the piston and burned up the rings and scared the cylender, had cylender replated and new piston and rings put in
05 KDX Hybrid
Tedh98
Post by Tedh98 »
Tedh98 wrote:Does the noise change/vary with the speed of the bike or engine RPM?
05hybridchick923
No not that I could hear I either hear it or I don't doesn't vary
05 KDX Hybrid
Tedh98
Post by Tedh98 »
Since you said it was happening in the upper RPM's and it is either there or not (and doesn't vary), I"m going to say it has something to do with the KIPS trying to engage/disengage.
That is really the only thing I can think of that would act kind of like a switch. Most other noises are going to vary based on either the speed of the bike or engine RPM.
Did you rebuild the top end or have a shop do it?
scheckaet
Post by scheckaet »
wrong jetting? too lean maybe?
you should be able to ride wide open and not seize the engine...
scheckaet
Post by scheckaet »
05hybridchick923
The person I bought it from did the work sent the cylender to millenium for the replating
05 KDX Hybrid
05hybridchick923
Not sure what carb is jetted at
05 KDX Hybrid
05hybridchick923
my bike has 05 220 motor arntthe carberators diff between the 2
05 KDX Hybrid
scheckaet
Post by scheckaet »
difference between what?
05hybridchick923
scheckaet wrote:difference between what?
carbs. Are diff between the 200 and the 220
05 KDX Hybrid
Mr. Wibbens
Post by Mr. Wibbens »
05hybridchick923 wrote:>|<>QBB<
Unless it was RB'd
scheckaet
Post by scheckaet »
still don't understand what you mean.
Are you running a 220 carb on your 220 or a 200 carb?
The carbare different, the 220 is smaller than the 200 but it should work just the same on your 220.
Anyway; it doesn't matter what carb you have, the jetting procedure is still the same.
Has thanked: 9 times
Been thanked: 17 times
I'm guessing the size of the carb is unknown. The OP didn't build the bike, right? I'm going to assume that the 220 engine had a 220 carb with it. This is really irrelevant to the question anyway. When we talk about the procedure for jetting a 2 stroke, it is specific to 2 strokes, but bike and size of carb do not matter. You must follow the same steps regardless.
This might be asking too much, but if you could get a digital audio file of the sound, like a short video if you have a digital camera, or just sound if you have a digital audio recorder. You email it to one of us and we can get it online for you somewhere so folks can have a listen. I don't think this would be kips rattle, not under a load. I imagine it could be reed flutter, but it could also be something more serious. It is very hard to diagnose a sound without hearing the sound. Descriptions can be misleading...
Welcome to KDXRider, btw! That is a great looking bike!
scheckaet
Post by scheckaet »
05hybridchick923 wrote:it sounds fine other than the normal tap im used to hearing
What "tap"?
05hybridchick923
juliend wrote:I'm guessing the size of the carb is unknown. The OP didn't build the bike, right? I'm going to assume that the 220 engine had a 220 carb with it. This is really irrelevant to the question anyway. When we talk about the procedure for jetting a 2 stroke, it is specific to 2 strokes, but bike and size of carb do not matter. You must follow the same steps regardless.
I can try that bike im sure is built right ive know the guy for over a yr he has been building and working on bikes longer than ive been alive i just cant remember if he went with smaller carb or the other i will try recording the sound but how do i load it to here
05 KDX Hybrid
scheckaet
Post by scheckaet »
try youtube
Mr. Wibbens
do you have a cell phone that records video?
If so I can give you my digits and you can send it to me
05hybridchick923
Yeah my phone does both
05 KDX Hybrid
