New to this and there's tons to read
jaredXwoodsman
Just got some 2001 KX forks for my 2003 KDX. So from what I gather my front wheel and axle won't work with the KX forks. Am I right or wrong? So many threads to read so little time.
- rbates9
You are half right.
The KX forks use a larger axle than the KDX. RBDesings did make a axle mod but last I heard he stoped making them due to too many variations in forks. I used his axle mod on my fork swap and it worked great. The forks I used are 2000 KX forks so if he will do it for you it should work.
- scheckaet
it can be done but seems more complicated than getting wheel, axle and spacer along with the fork.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- scheckaet
too many variable from year to year. He stopped making them for that reason.rbates9 wrote:You are half right.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
jaredXwoodsman
- rbates9
Swapping bearings probably will not work. Turning down the axle will not work because it is hollow and not thick enough to cut that much off.
Someone on here posted that they used the axle mod after RBD stoped making them so maybe he will do it on a case by case basis, might be worth a call.
I have a KX hub and axle but I'm not sure what I'm doing with them yet.
jaredXwoodsman
So can I swap hubs?rbates9 wrote:Swapping bearings probably will not work. Turning down the axle will not work because it is hollow and not thick enough to cut that much off.
jaredXwoodsman
jaredXwoodsman
ditton
Hi there.
Yep, RB may do the axle mod for you still. He did one for me but I had been in talks/e-mails with him just as he decided to stop doing them. He did however have the measurements for my set-up ('03 KDX & wheel, 03 KX125 Trees/forks). It was cheaper than buying a KX wheel and axle and I still get use the odometer.
Aslo had him do the stem swap and spacer spacer for the trees.....don't forget that you need that too for the KX Clamps
RB Designs work was top notch, clean and fit to a "T", return package was second to none.....and got a couple of cool stickers to boot.
Ditton
Ditton
jaredXwoodsman
That was my next and last question. Can I still use my odometer?ditton wrote:Hi there.
Ditton
ditton
Hello again.
You will not be able to use the odometer with the KX wheel/axle.
The only way I know of is the RB axle mod which will allow you to use the KDX wheel on KX forks......Unless you know a local machinist that can do this for you.
If you want to use the odometer, I highly recommend contacting RB and see if he can/will do the axle mod for you.....doesn't hurt to ask if you are interested.
Remember, you will also need to have the KDX steering stem put on the KX clamps and a spacer to make it fit properly when back on bike.
Hope this helps
Ditton
Hope this helps
Ditton
- Mr. Wibbens
This drawing should get you close to the right dimensions
(most of the dimensions were a bit oversized for my application)
- Mr. Wibbens
I believe steering stem sleeve was right on the money
