Quick coolant question
Posted: 03:25 am May 27 2010
by Alexander220
So I'm about halfway through a top end rebuild on an '00 220 and was just wondering how much coolant to fill it with and what kind to use. Also I've heard the 220 has a heating problem and was wondering if anyone could shed some light on that because I am considering removing the airbox lid after the top end which would lean I out (hotter engine). Thanks guys[/i]
Posted: 06:08 am May 27 2010
by Julien D
You fill it up until it's full. There's a bleeder on top of the inlet on the head to let trapped air out. There should be another bleeder on top of the LH radiator you can loosen too so the left rad gets filled completely.
You may need to re-jet after removing the airbox lid, unless it's running rich as it is. If you jetted it with the lid on, removing the lid would require you to re-visit those settings.
Posted: 09:51 am May 27 2010
by Alexander220
I've got stock jetting so just remove and I'm good. Oh and what coolant should I run, just any 50/50 mix?
Posted: 10:25 am May 27 2010
by Julien D
Whatever you like, yep.
Posted: 10:35 am May 27 2010
by KDX4ID
Posted: 10:55 am May 27 2010
by scheckaet
same here
Posted: 10:58 am May 27 2010
by Indawoods
Peak 50/50... never had a boilover....
Posted: 09:13 pm May 27 2010
by ihatefalling
juliend wrote:You fill it up until it's full. There's a bleeder on top of the inlet on the head to let trapped air out. There should be another bleeder on top of the LH radiator you can loosen too so the left rad gets filled completely.
I wondered what those were for....thanks
Posted: 12:21 pm May 28 2010
by Alexander220
Alright cool. Have any of you guys tried puttin in a coolant additive like waterwetter or something similar. It might be worth a shot if not
Posted: 12:23 pm May 28 2010
by Indawoods
Why for? Unless you are having a overheating problem... it is a big waste of money.
