Just won a set of forks! Have some questions.
Posted: 05:01 pm Oct 26 2006
I am really excited!
I just won a set of '94 kx 250 forks on e-bay. I see that most people have used '96 and newer forks when they converted. I was wondering if any of you have any experience with '94 forks and whether they will be a noticeable improvement over the stockers. Should I keep looking for a newer set or will these work ok?
The reason I bought them is that the previous owner had already swapped out the stem for a klx stem (should be the same as kdx), so I would just have to bolt them on
. According to the seller, they were revalved by pro-action for woods riding. Another reason was that I would still be able to use the 43 mm seal driver I have.
I have a '98 wheel. I cross-referenced the parts and it appears that axle, axle holders and wheel bearings are the same part number. I hope this means that the wheel will bolt right up. The springs are 0.38 and I weigh 170# without gear, should I look into stiffer springs?
I'm just trying to get a feel for any issues I may be overlooking. Any comments or advice would be greatly appreciated.
Thanks!!!
Tony.
Thanks!!!
Tony.
