Stupid clicker question
Posted: 03:02 pm Aug 18 2006
				The question, I mean, not the clickers.
I put '95 KX 125 forks on my '02 KDX. Best thing since radial tires.
I'm running top and bottom clickers at 2 clicks out from full soft. I like it a whole lot, but I do seem to have a little wash out temndency when entering a corner under hard front braking. I think I should reduce the compression damping or increase the rebound damping. Or raise the forks in the triple trees, but I want to do that last because I like the way it is balanced, front to back, right now.
USD forks, the TOP clicker is COMPRESSION, the BOTTOM clicker is REBOUND, right?
I'll throw in another question while I'm here...
On my '95 KX 125, RETARDING the timing to the limits of suggested adjustability will move the power band down slightly, for a bit more at the bottom at the expense of over rev, Right?
Keep in mind I've got the purple rhodium two stage power bands
Karl
Karl
