Rear shock compression adjuster stripped
Posted: 09:06 pm Jan 30 2023
by JZ05220r
The flat head adjuster is stripped out on my rear shock. I have a full replacement for it. Also the replacement one came off another shock. I didn’t drill out the peening It just broke loose and came out really smooth anyways. Just wondering if I should use any thread sealer when reinstalling my replacement. Thanks
Re: Rear shock compression adjuster stripped
Posted: 10:46 pm Jan 30 2023
Make sure the threads are OK before putting it in.
No thread sealant necessary. Lube the two orings.
Posted: 11:38 pm Jan 30 2023
by JZ05220r
KDXGarage wrote: 10:46 pm Jan 30 2023
Thank you
Posted: 12:07 am Jan 31 2023
by JZ05220r
One more thing. I can’t find the piston band anywhere. Can I get away without replacing it?
Posted: 06:51 am Jan 31 2023
by Slick_Nick
Piston bands are available from places like SDI, technical touch, etc.
Posted: 01:30 pm Jan 31 2023
You need the band and the o-ring underneath it, 44 mm. There is just one o-ring. Look up Technical Touch.
Posted: 03:42 pm Jan 31 2023
by JZ05220r
KDXGarage wrote: 01:30 pm Jan 31 2023
I went on to their site yesterday and punched in both the e series and h series and none were available to each. Should’ve mentioned that earlier. But knowing that it’s a 44mm band is helpful. Just need to know the rest of the dimensions. Thanks
Posted: 06:12 pm Jan 31 2023
by Slick_Nick
JZ05220r wrote: 03:42 pm Jan 31 2023
Don’t worry about what bike a shock was fitted to. Just like KYB 46’s are the same basic fork no matter what bike they came on, so to are the shocks.
Posted: 11:23 pm Jan 31 2023
by JZ05220r
Slick_Nick wrote: 06:12 pm Jan 31 2023
Makes sense. Still looking regardless. Thank you.
Posted: 04:23 am Feb 02 2023
Would you be interested in a full rebuild kit?
viewtopic.php?f=69&p=223290#p223290
Posted: 01:53 am Feb 03 2023
by JZ05220r
Yes, actually let me make sure my moto sport order cancels then I’ll get back to you. Thanks
Posted: 04:21 am Feb 03 2023
Sounds good. Just e-mail me when you are ready. I have all the parts here.
