Turbine core silencer for E model discontinued?
Posted: 10:32 pm Nov 06 2022
I can’t find the turbine core anywhere, just the power core.....
Discussion group for KDX enthusiasts
https://kdxrider.net/forums/
JZ05220r wrote: 10:32 pm Nov 06 2022 I can’t find the turbine core anywhere, just the power core..... I’m looking at a universal turbine core but notice it slotted where it would connect the the expansion pipe. Not sure if this would slip over the fmf expansion pipe. Thanks
Oops I meant the e model lolSS109 wrote: 12:19 am Nov 07 2022 No, it's not discontinued. It's listed all over the place. RMATV, Motosport, CycleGear, Revzilla, even Amazon and more.
I’m interested. The silencer that came on my e model has answer etched in it ironically but it’s riveted so I can’t repack it and a bit beat up. If you could share a few pics I’d appreciate itsarrant wrote: 03:52 pm Nov 08 2022 I have an Answer SA Pro-2 for E-Series KDX available. Aluminum silencer with internal turbine core spark arrestor. Lines up and slips on perfectly with FMF pipe. Probably needs a cleanup/repack.
I will double check that tomorrow. Thanks for that tip with the sheet metal screw. It is definitely too beat up for my build and the look I’m going for.sarrant wrote: 07:28 pm Nov 08 2022 I will try to fish it out and get a pic, but are you sure the Answer silencer is riveted on both ends? Usually it is only one. Also, you can drill the rivet out and replace with a sheet metal screw upon reassembly.
Thank and I will double check. Thanks for the tip with the sheet metal screws. It is too beat up for the fresh look I am going for though.sarrant wrote: 07:28 pm Nov 08 2022 I will try to fish it out and get a pic, but are you sure the Answer silencer is riveted on both ends? Usually it is only one. Also, you can drill the rivet out and replace with a sheet metal screw upon reassembly.
How much money would you like for that. I think maybe I could have it cleaned and polished. Thankssarrant wrote: 05:57 pm Nov 09 2022 Not sure that this is a restoration quality piece either, but it is a nice forest service approved arrestor that is exact fit for E-Series KDX and should clean up and repack nicely.
I recall it as being very quiet.
Thanks for the pics. I can see that looking pretty nice if I cleaned it real good and painted it black. I’ll consider it. How much would you like for it? Thank yousarrant wrote: 05:57 pm Nov 09 2022 Not sure that this is a restoration quality piece either, but it is a nice forest service approved arrestor that is exact fit for E-Series KDX and should clean up and repack nicely.
I recall it as being very quiet, especially for aftermarket.
How about 50 + shippingJZ05220r wrote: 06:25 pm Nov 09 2022How much money would you like for that. I think maybe I could have it cleaned and polished. Thankssarrant wrote: 05:57 pm Nov 09 2022 Not sure that this is a restoration quality piece either, but it is a nice forest service approved arrestor that is exact fit for E-Series KDX and should clean up and repack nicely.
