Shock crossover
Posted: 03:13 pm Feb 11 2020
by EzLivn
Can anyone tell me if the shock used on 96-06 kdx’s was used on any other dirt cycle? I have yet to find a parts fiche with the o rings in the top deepening adjuster.
Re: Shock crossover
Posted: 03:15 pm Feb 11 2020
by EzLivn
EzLivn wrote: 03:13 pm Feb 11 2020 Can anyone tell me if the shock used on 96-06 kdx’s was used on any other dirt cycle? I have yet to find a parts fiche with the o rings in the top deepening adjuster.
dampening!
Re: Shock crossover
Posted: 04:38 pm Feb 11 2020
by pumpguy
Actually, It's DAMPING. To dampen means to make something wet.
Re: Shock crossover
Posted: 05:56 pm Feb 11 2020
by bufftester
KDXGarage will likely have the answer as he has all the secret Kawi books laying around his shop seemingly lol. I do know that most of the parts on the 200/220 shock are the same as those on the E200, 91-94 KDX250, 94-96 and 06-07 KLX250R/S, the 97-07 KLX300, 93-96 KLX650R and the 87-200 KX125/250/500. Not all those share the same shock length, but you could probably get pretty close. If you have the orings out you can measure them and order through a number of sources online (McMaster-Carr, etc).
Re: Shock crossover
Posted: 09:37 pm Feb 11 2020
Just measure and buy new viton.
Any reason you took the compression adjuster out? Were you changing oil?
Re: Shock crossover
Posted: 09:59 pm Feb 11 2020
by EzLivn
Thanks for the replies. Even appreciate the help from grammarguy. Yes I am doing an oil change and replacing leaky seal.
Re: Shock crossover
Posted: 10:03 pm Feb 11 2020
OK. Sounds good.
