2002 KDX 200 Fork Oil Air Gap
Posted: 04:19 pm Feb 25 2014
by Rooks
Changing out the front springs on a '02 KDX200 and was wondering what the nominal air-gap measurement is for these forks (as measured with no spring/fork fully compressed)? I've seen several posts mentioning oil volume...but have always preferred using the air-gap measurement...so I figured I'd ask.
Thanks in advance for your help.
Posted: 05:48 pm Feb 25 2014
by tirebiter
I'm running 120mm down, seems to work just fine. Using 5wt right now, but thinking about switching to 7.5 for a little more rebound..
Posted: 07:43 pm Feb 25 2014
by JasonK94Z
tirebiter wrote:I'm running 120mm down, seems to work just fine. Using 5wt right now, but thinking about switching to 7.5 for a little more rebound..
Going up in oil wt actually slows down rebound.
Re: 2002 KDX 200 Fork Oil Air Gap
Posted: 11:22 pm Feb 25 2014
by MCKDX220
I am currently at 130mm, no casing, 4 compression hs valve shims removed from each leg. .41 springs.
The recommendation in the manual is 100mm, which if I ran the stock compression valving and springs, that is what I would run.
Michael
Posted: 11:46 pm Feb 25 2014
by tirebiter
JasonK94Z wrote:tirebiter wrote:I'm running 120mm down, seems to work just fine. Using 5wt right now, but thinking about switching to 7.5 for a little more rebound..
Well duh, that's what I stated...
More rebound equals
slower, unless your from down under, then lord knows what's up or down..
Posted: 04:01 pm Feb 26 2014
by Rooks
Thanks so much for the replies. I'll start at 100 and take things from there.
Posted: 07:41 pm Feb 26 2014
by motogoalie1
Im at 130 mm from top per race tech. Im also sporting .41kg xr 600 springx
Posted: 09:58 am Mar 01 2014
by hsracer1962
to tirebiter. Mr well duh, your statement is in print you cant deny your error so just apologize and move on.
Posted: 11:09 pm Mar 01 2014
by tirebiter
hsracer1962 wrote:to tirebiter. Mr well duh, your statement is in print you cant deny your error so just apologize and move on.
Posted: 12:10 am Mar 02 2014
by JasonK94Z
There always has to be that one guy ...
Posted: 01:56 am Mar 02 2014
by Joshmcmillan
I think you two just had a mix up of words but were both implying the same thing.
To OP, sounds like 100mm is the way to go.
Posted: 12:17 pm Mar 02 2014
by motogoalie1
Using adjectives and adverbs can clarify ones meaning.
faster rebound action
or
less rebound damping
slower rebound action
or
more rebound damping
and stuff
Posted: 10:12 pm Mar 03 2014
tirebiter, maybe everyone does not use the same language as you.
Also, no need for misspelled foul language.
Posted: 06:35 pm Jan 07 2015
by hsracer1962
Rooks wrote:Thanks so much for the replies. I'll start at 100 and take things from there.
no you are wrong, more rebound means quicker.heavier viscosity oil / 7.5 vs 5 would result in slower { LESS } not more { quicker }. Well DUH so ends your lesson for today.
Posted: 03:55 am Jan 08 2015
Your lesson is "welcome to forums", also known as "you replied to a message from 10 months ago"
Do try to be mindful of the dates.
