Page 1 of 2
Headlight
Posted: 02:31 pm Jul 17 2012
by KDX200Diesel
i just bought this headlight off ebay and i kno i saw some ppl with the model
http://www.ebay.com/itm/110880105438?ss ... 3127wt_952 but how did you guys wire it???? i kno the wiring on the bike but there is 4 wires on the headlight on green one blue one white from lookin at it green looks like ground white and blue posi??? is it a 2 positive or is one a ing like on a car stero and i only wan the main light to work not the little one thx in advanced
Re: Headlight
Posted: 02:41 pm Jul 17 2012
by KDX200Diesel
k i found the other forum but did anyone figure out which was high and low beam?
Re: Headlight
Posted: 03:48 pm Jul 17 2012
by KDX200Diesel
blue wire is high white is low just incause some one in future needs to kno
Headlight
Posted: 04:01 pm Jul 17 2012
by KDX200Diesel
Headlight
Posted: 10:24 pm Jul 17 2012
by B737driver
I have the same headlight assy. I ran both the park and headlight to the old power wire. Not sure what to do if you want a switchable hi/low beam though.
There are a couple of threads relating to this headlight assembly if you do a search.
Looks great on your bike.
Re: Headlight
Posted: 12:20 pm Jul 18 2012
by KDX200Diesel
i thought bout puting a 3 way switch so i can get HI/Low/Off thx it was great for $30
Re: Headlight
Posted: 10:47 am Sep 27 2012
by edog600
I just got the same light. Blue is high and white is low beam. OK. There is also a green and a brown? Ar these both grounds? which ground is which? For now I just want to wire up the low beam, so.....white to red and which, green or brown goes to black? Thanks in advance
Headlight
Posted: 07:48 pm Sep 29 2012
by Slick_Nick
See my "H7 retrofit" thread for this exact light.
Re: Headlight
Posted: 10:34 pm Sep 29 2012
by edog600
Thanks. Did a search bit couldn't find anything. Used the wrong words
Re: Headlight
Posted: 11:29 pm Sep 29 2012
by edog600
HMMM. Still don't see it.
Re: Headlight
Posted: 12:06 am Sep 30 2012
by edog600
OK, found it. My bike is street legal, although I only trail ride and never have at night. My bike did not have a switch when I got it and the light is just always on and no high low beam switch. Should I wire it so both lights are always on? Just needs to appear street legal when going from trail to trail and on 2 tracks. So should I wire up the light and parking light or just the regular light? Thanks?
Re: Headlight
Posted: 05:42 pm Oct 07 2012
by edog600
HMMMM. Some more help would be great. Blue and white wires coming off main light, plus a green that may be a common ground? Then a brown and gree coming off the park plight with the green being spliced together. Main light seems best and brightest when only using the the blue or white (can't member which) and the green. Is this what I should use? Has me pretty confused.
Re: Headlight
Posted: 06:08 pm Oct 07 2012
by edog600
Re: Headlight
Posted: 06:11 pm Oct 07 2012
by edog600
I just need the main light. So obviuosly I disreguard the brown. Looking at it you would think you just use the blue and white but it works best using just one and the green. Is there spose to be low and high on the main plus the brown and green as a park light. Maybe that's it. Thanks guys
Re: Headlight
Posted: 07:32 pm Oct 07 2012
by edog600
OK I think I got it. Blue high beam, white low beam, brown parking light, green common ground. Gonna put it on this way and just wire up the blue and green so high is always on. If this is wrong please let me know. Thanks guys.
Re: Headlight
Posted: 09:53 am Oct 21 2012
by Dekon
How did your wring work for you?
Re: Headlight
Posted: 03:05 pm Oct 21 2012
by edog600
Seems OK. Wired it just like I mentioned above. When the bike is running the bright light is on, no hi lo, on off switch or parking light. This should work just fine for me.
Headlight
Posted: 07:07 pm Oct 21 2012
by Dekon
Cool, so you are running just the blue and green wires?
Re: Headlight
Posted: 01:03 am Oct 22 2012
by edog600
Yes. I havent ridden it yet but it seems to be just fine when I fire er up in the garage.
Re: Headlight
Posted: 01:54 am Oct 26 2012
by edog600
Dekon, did you get it hooked up?
