Headlight
KDX200Diesel
Headlight
Post by KDX200Diesel »
i just bought this headlight off ebay and i kno i saw some ppl with the model http://www.ebay.com/itm/110880105438?ss ... 3127wt_952 but how did you guys wire it???? i kno the wiring on the bike but there is 4 wires on the headlight on green one blue one white from lookin at it green looks like ground white and blue posi??? is it a 2 positive or is one a ing like on a car stero and i only wan the main light to work not the little one thx in advanced
KDX200Diesel
Re: Headlight
k i found the other forum but did anyone figure out which was high and low beam?
KDX200Diesel
Re: Headlight
blue wire is high white is low just incause some one in future needs to kno
KDX200Diesel
Headlight
B737driver
Headlight
Post by B737driver »
I have the same headlight assy. I ran both the park and headlight to the old power wire. Not sure what to do if you want a switchable hi/low beam though. :hmm:
There are a couple of threads relating to this headlight assembly if you do a search.
Looks great on your bike. :boogie:
Live to Fly
Fly to Live
KDX200Diesel
Re: Headlight
i thought bout puting a 3 way switch so i can get HI/Low/Off thx it was great for $30
edog600
Re: Headlight
Post by edog600 »
I just got the same light. Blue is high and white is low beam. OK. There is also a green and a brown? Ar these both grounds? which ground is which? For now I just want to wire up the low beam, so.....white to red and which, green or brown goes to black? Thanks in advance
Been thanked: 17 times
Headlight
See my "H7 retrofit" thread for this exact light.
edog600
Re: Headlight
Post by edog600 »
Thanks. Did a search bit couldn't find anything. Used the wrong words
edog600
Re: Headlight
Post by edog600 »
HMMM. Still don't see it.
edog600
Re: Headlight
Post by edog600 »
OK, found it. My bike is street legal, although I only trail ride and never have at night. My bike did not have a switch when I got it and the light is just always on and no high low beam switch. Should I wire it so both lights are always on? Just needs to appear street legal when going from trail to trail and on 2 tracks. So should I wire up the light and parking light or just the regular light? Thanks?
edog600
Re: Headlight
Post by edog600 »
HMMMM. Some more help would be great. Blue and white wires coming off main light, plus a green that may be a common ground? Then a brown and gree coming off the park plight with the green being spliced together. Main light seems best and brightest when only using the the blue or white (can't member which) and the green. Is this what I should use? Has me pretty confused.
edog600
Re: Headlight
Post by edog600 »
edog600
Re: Headlight
Post by edog600 »
I just need the main light. So obviuosly I disreguard the brown. Looking at it you would think you just use the blue and white but it works best using just one and the green. Is there spose to be low and high on the main plus the brown and green as a park light. Maybe that's it. Thanks guys
edog600
Re: Headlight
Post by edog600 »
OK I think I got it. Blue high beam, white low beam, brown parking light, green common ground. Gonna put it on this way and just wire up the blue and green so high is always on. If this is wrong please let me know. Thanks guys.
Dekon
Re: Headlight
Post by Dekon »
How did your wring work for you?
edog600
Re: Headlight
Post by edog600 »
Seems OK. Wired it just like I mentioned above. When the bike is running the bright light is on, no hi lo, on off switch or parking light. This should work just fine for me.
Dekon
Headlight
Post by Dekon »
Cool, so you are running just the blue and green wires?
edog600
Re: Headlight
Post by edog600 »
Yes. I havent ridden it yet but it seems to be just fine when I fire er up in the garage.
edog600
Re: Headlight
Post by edog600 »
Dekon, did you get it hooked up?
