Page 1 of 2
Can anyone reccomend a good chain lube?
Posted: 04:04 pm Oct 03 2011
by Fatherof2
I have been using this stuff, and I hate it! It turns mud into a sticky mess that requires LOTS of elbow grease to get off!
Thank you,
David
Posted: 04:23 pm Oct 03 2011
by tirebiter
Try Maxima chain guard. Great stuff & easy to clean after..
Posted: 06:04 pm Oct 03 2011
by Slick_Nick
Posted: 07:09 pm Oct 03 2011
by SS109
This is what I use!
Posted: 07:31 pm Oct 03 2011
by diymirage
i wonder (and i appologize if this is a stupid idea) how chainsaw chain lube would hold up ?
it seems a chainsaw chain gets put through even more abuse then a KDX chain so if the lube works in that situation it should also work on the trails right ?
Posted: 07:33 pm Oct 03 2011
by scheckaet
forget it
by zomby woof
I think if you have an O ring chain, you don't really need to lube it. I spray a little penetrating oil on mine to keep it from rusting after washing.
Posted: 07:22 am Oct 04 2011
by Fatherof2
Thanks guys!
D.
Posted: 07:40 am Oct 04 2011
by gsa102
I use the Maxima lube on both O-ring and non O-ring chains. I think sticky is a good thing for lubrication.
Posted: 08:05 am Oct 04 2011
by fuzzy
Rem-oil rocks!
Chain bar oil is basically plain-jane motor oil.
Posted: 08:34 am Oct 04 2011
by dan46n2
Dupont Teflon lube from Lowes. Not nearly as much mess as others. Been using it on my streetbike for a few years now.
Posted: 08:53 am Oct 04 2011
by turtle
+1 on Maxima here.
Posted: 12:59 pm Oct 04 2011
by KarlP
For me, on an o-ring chain, no lube is the best lube.
the lube can't get anywhere it will do any good, anyway.
Posted: 01:38 pm Oct 04 2011
by cornishwrecker220
PJ1 blue lable....does exactly what it says on the tin....wont fly off.
Posted: 01:51 pm Oct 04 2011
by dan46n2
DID recommends lubing your chain, as the grease is only in certain areas of the chain.
http://www.didchain.com/chainMaintenance.html
YMMV.
Posted: 07:00 pm Oct 04 2011
by zomby woof
To guard against corrosion on O ring chains, which is the idea behind the penetrating oil.
Posted: 07:48 pm Oct 04 2011
by gregp
I run an o-ring chain (doesn't everybody?) and just spray it down with WD-40 after every ride, and wipe it off with a rag. It stays nice and clean (I have one of those fancy looking Gold ones). I have been using this method for years, and I have never noticed any accelerated wear, or any other issues. A chain/sprocket set usually lasts me at least a full year of casual trail riding use.
Posted: 09:05 pm Oct 04 2011
by nearma12
I've been using "Lucas Oil" Chain Lube. It is foamy when it comes out, then turns to liquid in a few seconds. That makes it easy to spray it where you want it. It also penetrates very well.
I hear lots of people say that they don't lube an O-ring chain. Just my opinion.....but, I think that the rollers still need a film of lube between them and the sprockets to reduce friction. At the very least. Right?
Posted: 10:19 pm Oct 04 2011
by zomby woof
No.
Nothing will stay there any longer then a few seconds.
by Slick_Nick
Its never a bad idea to lube an O ring chain.
