Hiccups
KDX220rser
Hiccups
What would cause a bike to give a Hiccup sound when blasting through gears. I will blast through all gears and when switching for 2-3 and 3-4 the bike will Hiccup right when I shift and give it WOT. Could this be my needle? bottom end response is good. Top-end power is brutal. Am I too lean or to rich? and what circuit?
Not a KDX but KTM guys want even answer my post.
09 250 xc-w
FMF gnarly/turbineCore2
Pilot-38
Main-162
Needle- (stock setting)
52 back sprocket.
Yellow spring in
PV 2.5 turns in from flush
09 250 xc-w
Pilot-38
Main-162
52 back sprocket.
Yellow spring in
09 KTM 250 XC-W
2005 KX-DX Hybrid
03 Ozark (under construction)
1978 Honda NC50 (under construction)
2005 KX-DX Hybrid
That main looks HUGE!
- fuzzy
- fuzzy
KDX220rser
KDX220rser
- fuzzy
KDX220rser
I raised the clip (lowering the needle). I have it jetted to the factory specs for my elevation and temp. I get confused with that though. When the weather gets hot, I will need to get more air? so I would need to lean out jetting during summer months, and richen up during winter? It has just started to do this. It has been pretty hot down here.
09 KTM 250 XC-W
2005 KX-DX Hybrid
2005 KX-DX Hybrid
Use your air screw for that.
- fuzzy
KDX220rser
KDX220rser
well then maybe it is my main... I am always WOT. I never really roll the throttle. I will try just rolling the throttle hard through all the gears and see at what throttle position the noise is coming from.
09 KTM 250 XC-W
2005 KX-DX Hybrid
2005 KX-DX Hybrid
