KX Suspension Mod
Posted: 05:52 am May 03 2010
by Byte
Greetings people.
I know you have all missed me..
Good to read you are all still here and keen as ever...
Wanting to know why is the KX suspension mod is done in the first place on the kdx?
Given that I would need to respring and revalve either KDX or KX forks, what is it about the KX forks that make this mod different to KDX forks?
Byte
Posted: 09:00 am May 03 2010
by Indawoods
Both rebound and compression adjustable. No underhang to hang you up and stiffer for much less flex....
Posted: 04:05 pm May 03 2010
by Byte
thanks Indawoods
what is this underhang you refer to?
Is it possible to safely use the KDX220 for MX play (and not racing) after the KX mod is done and rear suspension done?
Byte
Posted: 04:13 pm May 03 2010
by fuzzy
Look at how much of the fork leg is under the axle.
Yes.
Posted: 04:47 pm May 03 2010
by Byte
Thanks Fuzzy,
Do any of the KX125 or KX250 have 48mm forks? If so, which year?
Byte
Posted: 04:51 pm May 03 2010
by Indawoods
I know '03's are 48mm....
Posted: 04:54 pm May 03 2010
by scheckaet
01 are 46 and 02 are 48
Posted: 06:03 pm May 03 2010
by Brian
You can use the KDX for MX play even with the stock suspension. I have a KX 250 that's sprung for my weight and a KDX 220 with stock suspension and I take them both to the track.
The KDX is way too soft to even want to try the big jumps but it's kinda like a 125 in that it teaches you to corner faster and not waste energy.
Posted: 06:15 pm May 03 2010
by Colorado Mike
Yeah, unless you weigh about 40 lbs. with gear a KDX with stock suspension will make you very dead on jumps at the tracks in CO. Just go around them, rolling them could make you a landing pad.
Posted: 07:20 pm May 03 2010
by Julien D
Hitting jumps before and after switching my forks is not like hitting the same jump on the same bike. No comparison. I'm using outdated 43mm forks too, but I'm no longer scared to get the KDX up in the air a bit.
