Truing a wheel
kevfort19
Truing a wheel
Does someone have tips to true wheel, tools that i need, if it's easier to keep the wheel on the bike or, off the bike...the thing i have to know..
KDX 220 2001 =)
Don'T drink and drive...just give some gas and fly :D
SteveWR450f
Search this site. Someone was recently talking about it and then linked a video that was posted on thumper talk. I think it was a you tube video but it ran thru the all whole process of building and truing a rim.
I have seen a few guys keep the front wheel on the bike and then attach a zip tie to a brake cable going towards the rim. They were then able to eyeball where exactly the rim was out of true.
I am not that good. If I ever was going to try, I would remove the wheel and place on a truing stand. You can make one pretty easy.
WR sold. Now have 03 and 04 KDX 220s.
KXF 250 forks. RB Carb and Head. FMF rev pipe. Long live the KDX !!!
- scheckaet
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
Jupiter2
Tomm9050
- skipro3
Do the up and down first, then do the wobble.
Also, check out this link. I've used this method for building wheels. Follow the info for truing if that's all you are doing.
I recommend that you don't have the tire on when truing as well.
http://www.thumpertalk.com/wiki/build-a ... 90-minutes
- OLHILLBILLY
That is a great tutorial.skipro3 wrote:Do the up and down first, then do the wobble.
I second the tire off too, just makes everything work way easier.
Once you get your head around the idea, truing motorcycle wheels isn't all that big of a deal.
Once you get good at M-cycle wheels, you can move on the rear bicycle wheels. There you have to deal with "dish". Right side spokes are shorter than lefts, rim is offset from the center of the hub to allow for the 10 speed gear cluster, spoke tensions are different from one side to the other, spokes are hair thin, fragile, and stretch very easily, etc, etc..
2004 KDX 200.. Coupla mods
2009 KX250F.. Track Star
- scheckaet
I tuned mine "by hear", haven't tried it yet and I hope I didn't put too much tension on them. 1st ride will tell...
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- Mr. Wibbens
I did mine a few years ago
Some of the nipples needed persuading with some heat
Some I could not break free at all and had to replace the spokes/nipples
Jupiter2
- skythrasher
This a pretty good thread. One thing you may run into using this method, is the outer spokes being hard to lace. This is especially so if you are using oversize spokes. You can save yourself this headache by lacing the outers first. Doesn't matter which ones you thread in first, as long as you maintain the proper pattern. Sometimes it is not an issue, but placing outers first is always easier.skipro3 wrote:Do the up and down first, then do the wobble.
kevfort19
