Suitability of 2005 kx125 for kdx200 E2 hybird question
Posted: 01:40 pm Feb 03 2010
by gertie6car
Hi ,
I am hoping someone can give me some advice on the suitability of creating a hybrid from a kdx200 e2 and a 2005 kx125. I see there are a number using earlier kx donors - are there any issues with using the 2005 model?
Thanks in advance
Gert
Posted: 03:08 pm Feb 03 2010
by Tedh98
'04 and '05 should be the same. I'm working on my 2nd '04 hybrid.
'03 is very similar to '04-'05, but the rear suspension is a little different.
The only downside I've found with using the most recent models is that parts aren't as easy or cheap to find as prior years.
Posted: 08:44 pm Feb 03 2010
by dfeckel
I'm in the middle of a 2003 KX/1990 KDX build (E series engine).
The only real hiccup so far has been pipe fitment. You will need to modify a 95-up pipe to fit the E-series motor. The KIPS actuator arm on the right side of the cylinder protrudes much further on the E-series engines, and it interferes with the "low-boy" style pipe that you need for the late-model KX chassis. On the advice of well-informed sources, I got out the Big Frakking Hammer and put a big ol' dent in my shiny, new Pro Circuit pipe.
From what I understand, a PC pipe might bolt on perfectly with an H-series engine. That's what I was hoping for, but the E-series was just different enough that it wouldn't fit without a healty massage.
