jetting question
jowens66
jetting question
Post by jowens66 »
I just bought a 2005 KDX 220. I will be installing a FMF Gnarly Desert pipe and using the stock silencer. I have a twin air filter and the airbox top removed. A friend of mine has the CEK (3rd clip position) needle, 150MJ, and 40PJ that he will give me. My elevation is sea level to 3,000ft and temp is 50-90. Also, the bike has the stock 33mm carb. Would this be a good place to start for the jetting?
If your carb has not been modified by RB-designs then a CEL or DEL will be the needle you will want to use.
The DEK and CEK are best for modified carbs.
jowens66
jetting question
Post by jowens66 »
thanks...what clip position, PJ, and MJ should I use with the CEL needle?
Always start on the middle clip position with a new needle.
PJ and MJ help should be along shortly. I am a 200 guy and do not want to suggest that jetting in a 33mm carb.
You can look in the Members Profiles forum and check out some of their jetting on the 220's while you wait.
jowens66
jetting question
Post by jowens66 »
Thanks for the help. I know I will have to fine tune it, but I want to find a good starting point. I'll take your advise and look at some profiles while I wait for some 220 experts.
Thanks again
kevfort19
Post by kevfort19 »
i'm at 620ft altitude from sea level riding at the same temperature of you, my pilot is 40, JD jetting needle to 2 clip from te top, main jet 140 and 142, i have a fmf gnarly pipe with the powercore 2 silencer, airbox snorkel removed. IPONE S2 oil at 50:1. and it goes well
KDX 220 2001 =)
Don'T drink and drive...just give some gas and fly :D
Normski84
Post by Normski84 »
just a quick one i was looking on the Kehien website and it talks of Main Jets and Slow Jets is the Slow Jet the Pilot Jet or something tottally different please excuse my ignorance. :sad:
If at first you dont succeed.. Then push the other guy of his bike!!
Correct. The 'slow jet' is the pilot jet.
