Tossing my hat in the hybrid ring
Posted: 07:51 pm Apr 23 2009
Here is my hybrid that I just finished. It is a 2005 KX 125 chassis and a 2003 220 motor. Even though it took me all winter to finally finish I'm happy with the results. I rode it for a few hours this morning and think this will be a much better race bike than the KDX was. Here's some pics of the build
Here's what I started with,
l]
The frame with the new motor mounts, pipe hangers, and frame guards welded in place
I decided not to relocate the rear engine stay b/c I didn't want to run into issues with the gas tank fitting. So a customer of mine took a few measurements and made these brackets for me. Pretty cool huh?
One part of the build I didn't have a problem with was with the tank fitting. There must be some something different with the 2005 chassis I used and the 2003's that have been used before but I didn't have to make any modifications to the fuel tank and as a bonus the IMS big tank fit without needing modifications either
Here's a shot of the Moose sub-tank bars is used. I don't know anyone using them so I decided to be the guinea pig. The forks are 2006 KX 250F that I re-sprung, changed the ICS spring, installed Gold Valves and set the shims up as a dual stack better for off road racing. The shock was also re-valved using Race Tech parts. As a side note, I do have the KX 125 forks, triple clamps (with the stem removed) and front wheel that I would like to sell. If anyone is interested in them let me know.
I didn't want to put the CDI in the air box so I took the wiring harness apart, removed the wires used for the lights and extended the other wires so I could mount the CDI on the steering stem.
Something else that was a non issue with this build was that I was able to use a FMF Gnarly woods pipe and it fit perfectly, no bending or denting required.
A little protection for the Braking Wave rotor, a beefy ZipTy shark fin
Almost there...
And we're done. A few other parts of the build: Powder coated frame (I can't remember the exact color), Excel wheels and spokes, 18" for the rear, Dunlop 756's, a re-plated cylinder and new top end, FMF Gnarly pipe and Q Stealth silencer, Cycra Pro-Bend handguards, IMS 3 gallon gas tank, IMS pegs, UFO plastics, various new bearings and seals. The pipe guard and skid plate still need to be fitted as well as making up some KTM style radiator hoops but it was rideable this morning. It took me all winter to finish and it was worth it. Definitely a lot lighter steers SOOOO much better and the suspension kills the KDX. Can't wait to race it in too weeks.
l]The frame with the new motor mounts, pipe hangers, and frame guards welded in place
Almost there...
